Optoma DC550 Document Camera / Visualiser
Quicklinx: CHPWWS00 Mfr#: DC550
  • SDHC Memory Card
When it comes to teaching people, it's often the detail that counts and more is always better. Being able to share your ideas and knowledge with a large audience can be difficult but a huge benefit. With the Optoma DC550, you simply position items under the camera, connect it to a projector and show everything on the big screen live as it happens. The DC550 features an 8MP sensor, 544x total zoom and up to 30 frames-per-second video (at full resolution) for stunning image quality and performance allowing you to see detail often not visible to the human eye. Take photos or video using the camera function and include them in future presentation - it's all so easy. Create more engaging lesson content by easily capturing images, video and audio with the DC550 document camera. You can even take a video of a science experiment with the document camera, save it on your PC/laptop via USB or save to a SD card and use it in your next class and students can record their demonstrations during presentations for later review. The DC550 is powerful, robust and full of useful features that will revolutionize any classroom lessons or meeting room presentations.
Optoma DC550 - digital document camera
Digital document camera
Audio
Yes: built-in speaker, built-in microphone
8 cm x 16.6 cm x 52 cm
2.39 kg
Wired
Camera
Optical Zoom
17 x
Frame Rate (max)
30 frames per second
Video Modes
720p, 1080i, 1080p
Optical Sensor Type
CMOS - 1/3.2" - 8 MP
Focus Adjustment
Automatic, manual
USB 2.0, VGA, HDMI
1 - HDMI cable - external , 1 - USB cable - external , 1 - VGA cable - external
Voltage
DC 5 V
Picture-in-picture capability, digital image freeze, white balance, brightness control, image mirror, security lock slot (cable lock sold separately), auto white balance
Audio Support
Wired
8 cm
16.6 cm
52 cm
2.39 kg
Camera
Video Modes
720p, 1080i, 1080p
Digital Zoom
8
Frame Rate (max)
Flash Memory
128 MB
Image Sensor
8 MP CMOS 1/3.2"
Lens Construction
Optical Zoom
17 x
Focus Adjustment
Automatic, manual
Video
VGA, HDMI
Computer Interface
USB 2.0
Ports
VGA input , VGA , HDMI input , HDMI output , USB - 4 pin USB Type B
Supported Memory Cards
SDHC Memory Card
Microscope adapters, remote control
1 x HDMI cable - external , 1 x USB cable - external , 1 x VGA cable - external
Power Requirements
DC 5 V
Power adapter - external AC 120/230 V (50/60 Hz)
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.7 or later, Windows 10
System Requirements Details
Pentium 4 - 1.8 GHz - RAM 64 MB - HD 512 MB
