Visualize more detail for easy learning
When it comes to teaching people, it's often the detail that counts and more is always better. Being able to share your ideas and knowledge with a large audience can be difficult but a huge benefit.
With the Optoma DC350, you simply position items under the camera, connect it to a projector and show everything on the big screen live as it happens.
Information becomes clear and everyone shares your vision.
The DC350 features a 5-megapixel sensor, 40x zoom and 30 frames-per-second video (at full resolution) for stunning image quality and performance allowing you to see detail often not visible to the human eye.
Take photos or video using the camera function and include them in future presentation - it's all so easy.
Create more engaging lesson content by easily capturing images, video and audio with the DC350 Document Camera.
You can even take a video of a science experiment with the document camera, save it on your PC/Laptop via USB or save to a SD Card and use it in your next class and students can record their demonstrations during presentations for later review.
The DC350 is powerful, robust and full of useful features that will revolutionize any classroom lessons or meeting room presentations.
DC350 - enhancing the way we communicate.
Easy operation
Not all of us are experts when it comes to understanding new equipment, however, the DC350 is simple to use and easy to understand. Just turn on the Document Camera (Visualizer) connect it to a projector or panel and you are ready to go. Unlike many other Document Cameras, the main controls are on the base unit, so even if you lose the remote control the education does not stop. -
Amazing image quality
Display more detail with the latest 5MP CMOS sensor and full 720p output. Powerful 40x Zoom Capabilities for ultra-detail. -
Exceptionally smooth video performance
30 frames-per-second video at full resolution -
Record full-motion video at 30fps
Amazing quality image and video performance helps you to attract your audience's attention effectively. -
Save images directly to SD Card - max 32GB
Easily save images or video directly to SD/SDHC card. Recall your saved material from SD card anytime without connecting to a PC. Images can be saved at 0.8MP, 2MP, 5MP or 12MP for maximum flexibility and also quality. -
Capture it, save it
Sometimes we want to keep a memory of what the camera sees: by pressing the "SNAP" button on the remote control, or base unit images and video can be stored direct to a SD CARD. To review your images just hit the playback button. For permanent storage on a hard drive just connect a PC/Laptop using the supplied USB cable and software or save direct to your SD Card then you can review anytime anywhere. -
Flexible (gooseneck) arm
With an incredibly flexible neck, the DC350 is designed to help teachers and students with its ability to flex and bend, so allowing you to get up-close and personal to capture that perfect image. -
Picture-in-picture, capture, freeze, rotation, flip
With the DC350 you have ultimate control. Want to freeze something under the camera whilst handing out the original, or perhaps compare items using the Picture-in-Picture "PIP" so that comparisons can be made between one item and another. It's all easy for the Optoma DC350 Document Camera (Visualizer). -
Record audio and video
The built in microphone enables easy video with audio recording to create multimedia content for lessons and student presentations. -
Eco-friendly LED illumination (3 x mode brightness)
Sometimes you need a bit of extra illumination. The DC350 uses eco-friendly; low power LED lamps which are cool to the touch and mercury free, however, due to the excellent sensitivity of the camera the lamp is seldom required. The LED light has 3 light levels for even more flexibility -
Power from USB
The DC350 can also power up from a single USB port if you don't have access to a power plug, this also cuts down on cable mess and also makes the DC350 more flexible to move around a classroom or meeting room.
- Optoma DC350 - digital document camera
- Digital document camera
- Audio
- Yes: built-in speaker, built-in microphone
- 16 cm x 20 cm x 40 cm
- 1.2 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 5 x
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/3.2" - 5 MP
- Focus Adjustment
- Automatic, manual
- USB 2.0, VGA
- Cables Included
- 1 - VGA cable - external , 1 - USB cable - external
- Voltage
- DC 5 V
- Digital image freeze, SD-card slot, brightness control, image mirror, USB powered
- 3-year warranty
- Audio Support
- Wired
- 16 cm
- 20 cm
- 40 cm
- 1.2 kg
Camera
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 8
- Frame Rate (max)
- Still Image Capture Resolution
- 1280 x 720
Image Sensor
- 5 MP CMOS 1/3.2"
Lens Construction
- Optical Zoom
- 5 x
- Focus Adjustment
- Automatic, manual
- Video
- VGA
- Computer Interface
- USB 2.0
- Interfaces Details
- 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable - external , 1 x USB cable - external
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external
- OS Required
- Microsoft Windows XP, Microsoft Windows 7
- System Requirements Details
- Windows XP/7 - Pentium 4 - 1.8 GHz - RAM 64 MB - HD 512 MB
- Limited warranty - 3 years
