When it comes to teaching people, it's often the detail that counts and more is always better. Being able to share your ideas and knowledge with a large audience can be difficult but a huge benefit.
With the Optoma DC450, you simply position items under the camera, connect it to a projector and show everything on the big screen live as it happens.
Information becomes clear and everyone shares your vision.
The DC450 features a 8-megapixel sensor, 80X total zoom (10X optical zoom / 8X digital zoom) and up to 30 frames-per-second video (at full resolution) for stunning image quality and performance allowing you to see detail often not visible to the human eye.
Take photos or video using the camera function and include them in future presentation - it's all so easy.
Create more engaging lesson content by easily capturing images, video and audio with the DC450 Document Camera.
You can even take a video of a science experiment with the document camera, save it on your PC/Laptop via USB or save to a SD card and use it in your next class and students can record their demonstrations during presentations for later review.
The DC450 is powerful, robust and full of useful features that will revolutionize any classroom lessons or meeting room presentations.
Versatile connectivity
Equipped with mini HDMI, VGA, and USB ports, the Optoma DC450 document camera offers flexible connection options to seamlessly integrate with a wide range of devices. -
High-quality imaging
Featuring an 8,000,000 pixels CMOS optical sensor and a lens aperture range of f/2.8-3.5, this document camera delivers sharp, clear images for engaging presentations and detailed document examination. -
Dynamic focus adjustment
With both automatic and manual focus adjustments, the DC450 ensures your documents and objects are always in sharp focus, enhancing the clarity and impact of your visual aids. -
Powerful zoom capabilities
A 10x optical zoom and 8x digital zoom allow for detailed close-ups, making it easier to highlight specific content or examine documents closely, enriching the viewer's experience.
- Optoma DC450 - digital document camera
- Digital document camera
- Audio
- Yes: built-in speaker, built-in microphone
- 16 cm x 20 cm x 53 cm
- 1.65 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 10 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/3.2" - 8 MP
- Focus Adjustment
- Automatic, manual
- Lens Iris
- F/2.8-3.5
- USB 2.0, VGA, HDMI
- Cables Included
- 1 - mini HDMI-HDMI cable - external , 1 - USB cable - external , 1 - VGA cable - external
- Voltage
- AC 120/230 V DC 5 V
- Digital image freeze, SD-card slot, image mirror
- 3-year warranty
- Audio Support
- Wired
- 16 cm
- 20 cm
- 53 cm
- 1.65 kg
Camera
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 8
- Frame Rate (max)
- Still Image Capture Resolution
- 1280 x 720, 1600 x 1200, 1024 x 768, 1920 x 1080
Image Sensor
- 8 MP CMOS 1/3.2"
Lens Construction
- Optical Zoom
- 10 x
- Lens Iris
- F/2.8-3.5
- Focus Adjustment
- Automatic, manual
- Video
- VGA, HDMI
- Computer Interface
- USB 2.0
- Ports
- VGA input , VGA , Mini-HDMI , Mini-HDMI input , USB - 4 pin USB Type B
- Supported Memory Cards
- SDHC Memory Card
- Included Accessories
- Microscope adapters, remote control
- Cables Included
- 1 x mini HDMI-HDMI cable - external , 1 x USB cable - external , 1 x VGA cable - external
- Power Requirements
- AC 120/230 V - DC 5 V
- Power Device
- Power adapter - external
- OS Required
- Microsoft Windows XP, Microsoft Windows 7
- System Requirements Details
- Windows XP/7 - Pentium 4 - 1.8 GHz - RAM 64 MB - HD 512 MB
- Limited warranty - 3 years
