OCZ Synapse Cache Solid State Drives accelerate workstation and desktop computing applications with an innovative hardware-meets-software design and advanced caching feature-set.
The OCZ Synapse Series is optimized for caching applications to dynamically manage the Synapse SSD in conjunction with standard hard disk drives (HDDs), to provide users with SSD-level performance across the entire capacity of the HDD. The OCZ Synapse Series leverages the latest and most advanced hardware and software technology to deliver superior storage performance without sacrificing HDD capacity. For users craving the performance advantages of SSDs combined with the high capacities associated with HDDs, OCZ offers the first no-compromise approach to enabling high-performance and high-capacity storage for virtually any PC platform.
The OCZ Synapse Series integrates Dataplex caching software to dynamically manage the use of both SSD and HDD for superior overall storage performance.
- Random Write 4k: 75,000 IOPS
- Bandwidth up to 550 MB/s
- Usable SSD capacity up to 64GB
- Manages and accelerates full HDD capacity
High Performance SSD Architecture
- Maximizes performance with SATA 6 Gb/s interface
- Unleashes the full potential of today's leading platforms
- OS/application bootable with TRIM support
- Easy-to-deploy 2.5" solution for multiple drive bays
Integrated Dataplex™ Caching Software
- Intelligently manages HDD and SSD simultaneously
- "Hot" data managed on Synapse SSD for highest performance, access, and bandwidth
- "Cold" data routed to HDD for highest capacity usage
- No data migration or OS installation required
Keep the capacity. Let go of the Lag.
The OCZ Synapse Series integrates the benefits of SSD performance and HDD capacity with Dataplex™ caching software to dynamically manage the use of both SSD and HDD for superior overall storage performance. This combination creates an environment where the most frequently used "hot" data stays on the ultra-fast SSD, while the "cold" data remains on the larger capacity HDD (sold separately). Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user, maximizing productivity for the most demanded programs and applications. Synapse Series integrates seamlessly within any modern PC platform, ensuring optimal compatibility along with performance gains.
See The OCZ Synapse Cache Solid State Drives In Action!
- OCZ Synapse Cache - SSD - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Shock resistant, TRIM support, 256-bit AES, 128-bit AES
- 70 mm x 100 mm x 9.1 mm
- 79 g
- 3-year warranty
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 70 mm
- 100 mm
- 9.1 mm
- 79 g
Performance
- Internal Data Rate
- 550 MBps (read) / 510 MBps (write)
- 4KB Random Read
- 19000 IOPS
- 4KB Random Write
- 80000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Software Included
- Dataplex
- OS Required
- Microsoft Windows 7 (32/64 bits)
- Included Accessories
- 3.5-inch bay adapter
- FCC, RoHS
- Limited warranty - 3 years
- 0 °C
- 70 °C
