OCZ introduces the Vertex 460A for those seeking a high-performance yet value-minded SSD. Combining OCZ's own controller design and superior flash, Vertex 460A keeps your system ahead of the game and delivers a faster, more responsive PC experience.
Storage for your multimedia, multitasking world
The OCZ Vertex 460A Series delivers the performance, productivity, and energy efficiency you're craving from your system. Say goodbye to lag and get a computing experience worthy of your time. -
Performance that matters
Do you write a lot of data? Vertex 460A delivers leading write speeds that you won't get with any other solution. No fancy behind-the-scenes tricks, just pure storage performance. -
Do more than just store
Imagine faster file transfers, snappier boot ups, and system responsiveness that makes you wonder why you put up with that hard drive for so long. -
Reliability and durability from the inside out
With the quality technology built into every drive, the Vertex 460A Series is built to provide years of hard drive-humiliating performance. Ditch that spinning mechanical hard drive for some storage peace of mind.
- OCZ Vertex 460A - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- A19nm multi-level cell (MLC)
- Form Factor
- 2.5" x 1/8H (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Native Command Queuing (NCQ), shock resistant, TRIM support, OCZ Barefoot 3 M10 controller, S.M.A.R.T., 44/1K bit BCH ECC
- 69.75 mm x 99.7 mm x 7 mm
- 113 g
- 3-year warranty
- Capacity
- 240 GB
- 256-bit AES
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- 69.75 mm
- 99.7 mm
- 7 mm
- 113 g
Performance
- Internal Data Rate
- 540 MBps (read) / 525 MBps (write)
- 4KB Random Read
- 85000 IOPS
- 4KB Random Write
- 90000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H or 3.5" (with included bay adapter)
- Power Consumption
- 3.45 Watt
- Software Included
- Acronis True Image HD
- Included Accessories
- 3.5-inch bay adapter
- UL, VCCI, C-Tick, BSMI, FCC, KCC, WEEE
- Limited warranty - 3 years
- 0 °C
- 70 °C
