Get impressive graphics and high resolution quad-display performance from the NVIDIA GeForce GT 730 Graphics Card.
                Flexible connectivityEnjoy support for up to four displays from Dual-Link DVI and DisplayPort connectors.
                Smart memoryEliminate the need to share PC system memory with 2 GB DDR3 dedicated on-board graphics frame buffer memory.
                Broad application supportSupport your OpenGL 4.4 and DirectX 12 applications with compatibility integrated into the hardware.
- NVIDIA GeForce GT 730 - graphics card - GF GT 730 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express x8
- Graphics Engine
- Memory
- 2 GB DDR3
- Core Clock
- 902 MHz
- Effective Memory Clock
- 900 MHz
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , DisplayPort , VGA - with adapter
- API Supported
- DirectCompute 11, OpenGL 4.4, DirectX 12, OpenCL 2.0
- 1-year warranty
- Designed For
- HP 280 G3; EliteDesk 705 G2 (micro tower, SFF), 705 G3 (micro tower, SFF), 800 G2 (SFF, tower); ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF)
- Bus Type
- PCI Express x8
- Graphics Engine
- Core Clock
- 902 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- Shader Model 5.0, Kepler GPU Architecture
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 900 MHz
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8.1 64-bit Edition, Windows 10 64-bit Edition
- 27 Watt
- Cables Included
- 1 x DVI-VGA adapter
- UL, VCCI, BSMI, ACA, CISPR, ICES, KC
- Limited warranty - 1 year
- Designed For
- HP 280 G3 , HP EliteDesk 705 G2 (micro tower, SFF), 705 G3 (micro tower, SFF), 800 G2 (SFF, tower) , HP ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF)
|  | C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.42 |
|  | C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.94 |
