This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirement of high performance applications.
- C2G 20cm DisplayPort to HDMI Adapter - DP Male to HDMI Female - Black - DisplayPort cable - 20 cm
- DisplayPort cable
- Length
- 20 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- Black
- Limited lifetime warranty
- DisplayPort cable
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 30
- Length
- 20 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
