The NF-A14 is a premium quality quiet 140 mm fan with a square frame that complies with Noctua's AAO (Advanced Acoustic Optimization) standard. Its square shape and 140 mm mounting holes make it ideal for use on water-cooling radiators or as an upgrade for 140 mm case fans. Featuring sophisticated aerodynamic design measures such as flow acceleration channels, the NF-A14 further improves the renowned quiet cooling performance of the award-winning NF-P14. The FLX version provides 1200/1050/900 rpm speed settings via the supplied low-noise adaptors in order to provide full flexibility in fine-tuning the fan for maximum ventilation performance or near-silent operation. Its superb running smoothness, reference-class SSO2 bearing and Noctua's trusted premium quality make it an elite choice for the highest demands.
- Noctua NF-A14 FLX - case fan
- Product Type
- Case fan
- Package Content
- Ultra-Low-Noise Adaptor (U.L.N.A.), Low-Noise Adaptor (L.N.A.), 3-pin plug to 4-pin Molex adapter, 4 screws, 4 vibration isolators, 1 extension cable (30 cm)
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- SSO2 bearing
- Rotation Speed
- 900/1050/1200 rpm
- Air Flow
- 52.2-68 cfm
- Noise Level
- 13.8 - 19.2 dBA
- Power Connector
- 3-pin plug, 4 pin Molex connector
- Rated Voltage
- 12 V
- Advanced Acoustic Optimisation (AAO), flow acceleration channels
- 6 years warranty
- Product Type
- Case fan
- Package Content
Heatsink & Fan
- Fan Diameter
- 140 mm
- Fan Height
- 25 mm
- Fan Bearing
- SSO2 bearing
- Rotation Speed
- 900/1050/1200 rpm
- Air Flow
- 52.2-68 cfm
- Air Pressure
- 0.89-1.51 mm
- Noise Level
- 13.8 - 19.2 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.08 A
- Power Consumption
- 0.96 W
- Mounting Kit
- Included
- MTBF
- 150,000 hour(s)
- Limited warranty - 6 years
