Newlink USB 2.0 To 10/100 Ethernet Adaptor B/Q 20 233MHz 64MB
Quicklinx: C494WS00 Mfr#: NLUSB2-ETHRJ
The USB 2.0 Ethernet adapter allows your computer to instantly connect to a 10 / 100 Mbps network through a USB port. This is an easy way to add network connectivity without the hassle of opening your computer case and installing an internal card. It’s also an ideal USB-to-LAN alternative for games consoles that need network access in an environment lacking wireless capability. Compared with the USB 1.1 standard which offers 12 Mbps speed, the adapters compliance with USB 2.0 (480 Mbps) ensures true 10 / 100 Mbps network speed. Furthermore, the adapter is compact and powered solely by the USB port so no external power supply is needed.
NEWlink NLUSB2-ETHRJ - network adapter - USB 2.0 - 10/100 Ethernet
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0
Apple MacOS X 10.0 or later, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 / 8.1
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
WOL, half duplex mode, full duplex mode, USB powered
1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
1 x USB cable (integrated)
Plug and Play
Software Included
Drivers & Utilities
System Requirements Details
233 MHz - RAM 64 MB
