NetPro 300N DSL/ CABLE ROUTER
Quicklinx: 6B1MWS00 Mfr#: NPWRN
  • IEEE 802.11n (draft 2.0)
The Netpro Wireless Hi-Gain Router allows you to easily set up a wireless network. It will enable you to share your internet connection as well as all your files, pictures, music and videos. It will also allow all users to share devices such as printers and scanners all without the need for wires! Setting up the router and keeping everything secure is very easy thanks to the automatic transfer of all security settings direct from the router. The easy to use installation guide means anyone can set up and secure a wireless connection without the need of any technical skills! It's so easy, your wireless network can be up and running in less than a minute. Once everyone is connected to the internet then you may need some additional security, so we have also included AVG Internet Security software to help protect your computers!
Technical Info:
Wireless N Broadband Router
1 WAN Port + 4 Port Switch + IEEE 802.11b/g/n AP
Complies with Draft 802.11n
The product complies with Draft 802.11n next generation wireless standard. Utilising the advanced MIMO technology, it can support the data transmission rate of up to 300Mbps and the coverage distance is greater than IEEE 802.11g/b products. A stable wireless connection and high bandwidth enable you to enjoy the network applications without any interruption.
Wi-Fi Protected Setup (WPS)
This router supports you to build the connection between wireless network client and the router by simply pressing the WPS button on the wireless client and the router. No need to set up and configure the security on a wireless network.
l.P Sharing
The NAT/NAPT function lets you share the ADSL line to all the Intranet users (support up to 253 users). It also provides virtual server and virtual DMZ functions to let your internal servers be accessed from the Internet.
Supports Special Applications
The router can let you setup trigger ports of special applications, and let you utilize Internet services smoothly.
Virtual Server and DMZ
The virtual server and DMZ function let you setup your servers in the Intranet and still can provide services to the Internet users. DHCP Server
Automatically assign IPs to the Intranet PCs.
Web Configuration
You can configure the router through the friendly Web user interface with a browser.
Technical Features:
Router Features
  • NAT/NAPT IP Sharing
  • Obtain WAN IP by PPPoE/Static IP/PPTP/DHCP
  • Virtual Server/DMZ/Port Forwarding
  • Supports Special Applications (Port Triggers)
  • Supports DDNS (DynDNS, TZO)
  • VPN Pass Through (IPSec/PPTP)
  • Anti-DoS Firewall
  • DHCP Server
  • Web User Interface (Remote Configuration)
  • System Status and security logs
  • Firmware Upgrade
