The NETGEAR N300 wireless router and USB adapter kit is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. It provides a complete solution with wireless router and USB adapter, and free parental controls to ensure a safe Internet experience.
Enhanced security
With a suite of features including 128-bit WEP, 64-bit WEP, WPA-PSK, and WPA2-PSK encryption algorithms, the NETGEAR WNB2100 ensures your network remains secure against unauthorized access and threats. -
Seamless connectivity
Offering both wired and wireless connectivity options, this device supports Ethernet, Fast Ethernet, and IEEE 802.11b/g/n protocols, ensuring a reliable and fast connection for all your devices. -
Comprehensive control
Equipped with Quality of Service (QoS), Stateful Packet Inspection (SPI), and Wi-Fi Protected Setup (WPS), the NETGEAR WNB2100 provides you with the tools to manage your network efficiently, prioritize traffic, and simplify setup. -
Versatile compatibility
Designed to work seamlessly with Mac, PC, and Unix systems, the NETGEAR WNB2100 offers broad compatibility, making it a versatile choice for a wide range of network environments.
- NETGEAR WNB2100 - wireless router - Wi-Fi - desktop - with NETGEAR WN111 RangeMax Next Wireless-N USB Adapter
- Wireless router - 4-port switch (integrated) - with NETGEAR WN111 RangeMax Next Wireless-N USB Adapter
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- Remote Management Protocol
- HTTP
- Firewall protection, NAT support, SPI, DoS attack prevention, IDS, URL filtering, firmware upgradable, WMM support, QoS, WPS
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
- 17.8 cm x 13 cm x 3.5 cm
- 399 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows Vista / 2000 / XP
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- Status Indicators
- Port status, power
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x RJ-45
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 17.8 cm
- 13 cm
- 3.5 cm
- 399 g
