The NETGEAR N300 Wireless Router with USB is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. Storage for downloads is easy with ReadySHARE™ for shared access to a USB storage device.
- NETGEAR WNR2200 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- TCP/IP, PPTP, PPPoE, DHCP, SMB
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- HTTP
- Repeating mode, dynamic DNS server, E-mail alert, MAC address filtering, WDS support, URL filtering, firmware upgradable, WMM support, QoS, WPS, DHCP server, port forwarding, ReadySHARE
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 17.3 cm x 12.8 cm x 3.2 cm
- 270 g
- Microsoft Certification
- Compatible with Windows 7
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Routing Protocol
- HTTP
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, VCCI Class B ITE, EN55022, CISPR 22, FCC Part 15 B
- Status Indicators
- Port status, power
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 17.3 cm
- 12.8 cm
- 3.2 cm
- 270 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
