Brand
NETGEAR WiFi 6 WAX214 Access Point
Quicklinx: GCZNWS00 Mfr#: WAX214-100EUS
  • IEEE 802.11n (draft 2.0)
Hurry, only 1 left in stock!
£86.75 ex VAT
£104.10 inc VAT
Express delivery Order within the next 18 hours for delivery on Monday
The NETGEAR Wi-Fi 6 AX1800 PoE Wireless Access Point (AP) delivers 802.11ax high performance wireless connectivity for Small Office and Home Office (SOHO) deployments and supports dual band concurrent Wi-Fi 6 operations at 2.4GHz and 5GHz with a combined throughput of 1.8Gbps (600Mbps at 2.4GHz and 1200Mbps at 5GHz). The WAX214 Wi-Fi 6 Access Point provides standalone configuration with easy setup for a reliable, Wi-Fi 6 802.11ax high performance, and cost-effective wireless solution. The WAX214 can be powered by Power-Over-Ethernet or a DC power adapter.
NETGEAR WAX214 - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum throughput (2.4 GHz): 573.5 Mbps , Maximum throughput (5 GHz): 1201 Mbps
SSIDs total: 4
16.09 cm x 16.09 cm x 3.328 cm
380 g
3-year warranty
Radio access point
16.09 cm
16.09 cm
3.328 cm
380 g
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
SSIDs total: 4
Wi-Fi Rating
AX1800
Status Indicators
Power, LAN, 2.4/5 GHz
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, SOHO (Small Office/Home Office)
Encryption Algorithm
WPA, WPA2, WPA3
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
1 x 1000Base-TX (PoE+) - RJ-45
1 x network cable
EN 60950, CB, EN 62368
Limited warranty - 3 years , Technical support - 90 days
95%
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11n (draft 2.0)
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: 802.11ax
Brand: NETGEAR
Stock Status: While stocks last
Stock Status: Clearance
