The NETGEAR 3 AP pack of WAC720 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4GHz and 867 Mbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC720 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
Enhanced security
With a suite of features including Extensible Authentication Protocol (EAP), RADIUS, and WPA2 encryption, this access point ensures a secure network environment, safeguarding sensitive data from unauthorized access. -
Robust connectivity
Equipped with Dual Band Wireless-AC technology, the device offers aggregate throughput of 1.2 Gbps, with up to 300 Mbps on the 2.4 GHz band and 867 Mbps on the 5 GHz band, ensuring high-speed Internet access for multiple devices. -
Versatile networking
Supports a wide range of networking protocols and features such as VLAN support, VPN support, and Multiple SSID support, providing flexible configuration options to meet various business networking needs. -
Comprehensive management
Remote management protocols including SNMP, CLI, and HTTP, allow for easy setup, monitoring, and maintenance of the network infrastructure from anywhere. -
Efficient installation
Power over Ethernet (PoE) capability simplifies deployment by eliminating the need for a separate power supply, enabling flexible placement and reducing installation costs.
- NETGEAR Business 2 x 2 Dual Band Wireless-AC Access Point WAC720 - radio access point - Wi-Fi 5
- Radio access point
- Packaged Quantity
- 3 (specifications are for single item)
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
- Included Accessories
- Wall mounting kit, ceiling mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- 19.7 cm x 19.7 cm x 4 cm
- 726 g
- NETGEAR lifetime warranty
- Packaged Quantity
- 19.7 cm
- 19.7 cm
- 4 cm
- 726 g
- Form Factor
- External
- Connectivity Technology
- Wired
- Bonjour
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Status Indicators
- Power, LAN, wireless, link/activity
- VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, 802.1x authentication, Transmit Power Control (TPC)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- External detachable and internal
- 1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 2 x aerial - RP-SMA
- Cables Included
- 1 x network cable
- PoE
- Limited warranty - lifetime
