The NETGEAR WAC104 Wireless Access Point is a cost-effective, high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2Gbps. To fully maximize the wireless throughput, the WAC104 is equipped with four Ethernet ports. WAC104 AP operates in standalone mode with an intuitive user interface and a set of two external antennas. It is perfectly positioned for customers demanding high throughput, ultra -superior performance, and extensive coverage deployment for Small and Home Office environments.
Enhanced connectivity
With dual-band support, the NETGEAR WAC104 offers Wi-Fi bands of 2.4 GHz and 5 GHz, ensuring a more stable and faster wireless connection. This flexibility allows for less congested networking, providing a smoother online experience for video streaming, gaming, and web browsing. -
Robust security
The NETGEAR WAC104 is equipped with multiple encryption algorithms including WEP, WPA-PSK, and WPA2-PSK, alongside features like Access Control List (ACL) support and MAC address filtering. This comprehensive suite of security features ensures that your network remains protected against unauthorized access and data breaches. -
Versatile performance
Featuring support for multiple IEEE standards including 802.11a, 802.11ac, 802.11b, 802.11e, 802.11g, and 802.11n (draft 2.0), the WAC104 is designed to deliver reliable wireless performance. Its capacity to handle up to 128 clients makes it an ideal choice for businesses looking for a scalable and efficient networking solution.
- NETGEAR WAC104 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Ports Qty
- 4
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of clients: 128
- 23.965 cm x 18.145 cm x 4.06 cm
- 385 g
- 3-year warranty
- 23.965 cm
- 18.145 cm
- 4.06 cm
- 385 g
- Localisation
- United Kingdom
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.2 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
- Power, LAN, wireless, WPS
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), wireless bridge mode, SOHO (Small Office/Home Office)
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- Basic Service Set Identifier (BSSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n (draft 2.0), IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Gain Level
- 3 dBi
- 4 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- MTBF
- 100,000 hours
- EN 60950
- Power Device
- External power adapter
- 8.1 watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90%
