NETGEAR RangeMax 150 Wireless Router (V2)
Quicklinx: 72GXWS00 Mfr#: WNR1000-100UKS
The NETGEAR N150 Wireless Router is a simple and secure way to share your high-speed Internet connection at Wireless-N speeds for surfing the Internet, email, online chat and Facebook. Easy setup with the Smart Wizard CD gets you up and running fast, while Wi-Fi Protected Setup gives you a secured connection at the push of a button. Compatiblity with Wireless-G networks allows hassle-free connection flexibility.
Surf, email, chat
Share your Internet connection
Smart Wizard™ -- easy setup
Free Parental Controls
Provides better wireless coverage than older Wireless-G routers
Extra performance boost when connected to Wireless-N devices
Surf, e-mail, stream music, play on-line games, and make Internet phone calls
Push 'N' connect can securely connect devices at the push of a button
Convenient on/off switch helps save energy when not in use
Efficient Energy Star compliant power supply
Packaging manufactured with at least 80% recycled materials
NETGEAR RangeMax WNR1000 - wireless router - 802.11b/g - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Remote Management Protocol
HTTP
Firewall protection, DMZ port, auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, E-mail alert, VPN passthrough, URL filtering, parental control, Wi-Fi Protected Setup (WPS)
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup
Environmental Standards
ENERGY STAR Qualified
2.8 cm x 11.8 cm x 17.5 cm
399 g
UNIX, Apple MacOS, Linux, Microsoft Windows Vista / 2000 / XP
United Kingdom
Enclosure Type
Desktop
Wireless, wired
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
ENERGY STAR Certified
Vertical stand
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
2.8 cm
11.8 cm
17.5 cm
399 g
