NETGEAR R6220 Wireless Router 4-Port Switch GigE - 802.11a/b/g/n/ac
Quicklinx: CDWQWS00 Mfr#: R6220-100UKS
  • IEEE 802.11n
Keep your many Wi-Fi devices streaming effortlessly with AC Wi-Fi technology that delivers the speed, range, and reliability you need. Avoid wireless interference with simultaneous dual bands. Play games on your tablet. Listen to tunes on your smartphone. View movies on your media player. Whatever you want to do, you're covered.
  • Speed
    Everything you need for a fast, fast, fast connected home. Next generation 11ac Wi-Fi with dual band technology provides whole home coverage with Gigabit wired connections.
  • Wi-Fi range
    Got range? Homes come in all shapes and sizes and R6220 smart Wi-Fi router provides Wi-Fi coverage no matter where you connect in your home.
  • Reliability
    There's nothing more frustrating than lost connections! With NETGEAR's advanced features & best-in-class technology, you'll reduce interference & enjoy more reliable Wi-Fi connectivity.
  • Sharing
    With NETGEAR, sharing across your network is fun and easy, anything from accessing stored photos & music to wireless printing.
  • Ease of use
    Start enjoying your device faster than ever .NETGEAR wants to make sure installation and management is simple & easy, so you can connect quickly & make sure you stay that way!
  • Security
    Maintain the highest security across your network to ensure your privacy & family is safe while online. Whether it's preventing phishing & spyware or just limiting access for kids & guests, NETGEAR has you covered.
NETGEAR R6220 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Remote Management Protocol
HTTP
Firewall protection, auto-sensing per device, NAT support, SPI, DoS attack prevention, IPv6 support, parental control, firmware upgradable, QoS, WPS, ReadySHARE, Push ‘N’ Connect button, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
23.965 cm x 18.145 cm x 4.06 cm
385 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK
880 MHz
RAM
128 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
23.965 cm
18.145 cm
4.06 cm
385 g
Limited warranty - 1 year
