NETGEAR ProSafe Wireless N VPN/SSL Firewall
Quicklinx: 5DYXWS00 Mfr#: SRXN3205-100EUS
  • IEEE 802.11n (draft 2.0)
NETGEAR's SRXN3205 ProSafe Wireless-N VPN Firewall offers two types of virtual private network (VPN) tunnels, Secure Sockets Layer (SSL) and IP security (IPsec), for optimal secure connection to your network. SSL VPN tunnels provide clientless remote access to your corporate data for individual access anywhere and anytime without a software client. IPsec VPN tunnels deliver both secure site-tosite tunnels and legacy remote access support, connecting multiple offices together, as well as clientbased remote access. Backed by a sophisticated firewall, the SRXN3205 is a high-performance, SNMP-manageable security solution that furnishes multidimensional security including denial-ofservice (Dos) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Four Gigabit LAN ports in conjunction with an integrated dual band Wireless N Access Point keep your data moving at top speed.
The SRXN3205 Wireless-N VPN Firewall takes care of all your security needs, with support of up to 5 SSL VPN tunnels and 5 IPsec VPN tunnels simultaneously, hacker protection via SPI firewall, Dos attack protection, and multiple VPN pass-through. SYSLOG and email reporting enable thorough network monitoring. The SSL VPN tunnels support industry-strength encryption algorithms and features such as automatic cache cleanup after session termination to ensure protection and privacy of your sensitive data. The SRXN3205 Wireless-N VPN Firewall provides optimal value and defense against network security threats.
  • Enhanced security
    With a suite of encryption algorithms including 128-bit WEP, 256-bit AES, and Triple DES, alongside firewall protection, stateful packet inspection (SPI), and VPN support, the NETGEAR ProSafe SRXN3205 ensures your network remains secure against external threats.
  • Robust connectivity
    This wireless router supports a wide range of data link protocols including Ethernet, Fast Ethernet, Gigabit Ethernet, and 802.11a/b/g/n (draft 2.0), ensuring versatile and high-speed connectivity options for all your devices.
  • Comprehensive VPN support
    Offering up to 5 SSL and IPSec VPN tunnels, the device facilitates secure and efficient remote access, making it suitable for businesses with remote employees or multiple office locations.
NETGEAR ProSafe SRXN3205 - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Performance
VPN throughput: 20 Mbps , Throughput: 60 Mbps
SSL VPN tunnels: 5 , IPSec VPN tunnels: 5 , Concurrent connections: 20000
Network / Transport Protocol
IPSec
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 2, HTTP
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), Syslog support, SPI, DoS attack prevention, E-mail alert, VPN passthrough, URL filtering, QoS, DHCP server
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0)
25.3 cm x 18 cm x 3.5 cm
1.3 kg
Europe
Enclosure Type
Desktop
Wireless, wired
Performance
IPSec
Routing Protocol
Static IP routing
SNMP 2, HTTP
Encryption Algorithm
DES, Triple DES, MD5, ARCFOUR, 128-bit WEP, 64-bit WEP, SHA-1, TLS 1.0, SSL 3.0, PEAP, TTLS, TKIP, WPA, WPA2, PKI, 256-bit AES
Authentication Method
RADIUS
300 MHz
RAM
64 MB
Flash Memory
16 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
Europe
Software Included
Drivers & Utilities, ProSafe VPN Client (1 user licence)
25.3 cm
18 cm
3.5 cm
1.3 kg
Resources
The following resources are available for the NETGEAR ProSafe Wireless N VPN/SSL Firewall
