Product
Brand
NetGear ProSafe Wireless-N Single Band Access Point
Lifetime warranty
Quicklinx: 8TPBWS00 Mfr#: WN203-100UKS
  • IEEE 802.11n
The NETGEAR ProSAFE WN203 Wireless-N Access Point provides standalone configuration for easy setup for a reliable, high-performance and affordable 802.11n wireless solution for small or medium businesses. Power over Ethernet enables flexible deployment and multiple SSID provide enhanced security.
NETGEAR ProSafe Wireless-N Single Band Access Point WN203 - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Virtual interfaces (VLANs): 64
Vertical stand
Power Over Ethernet (PoE) Supported
PoE
13.3 cm x 17.3 cm x 3.5 cm
240 g
NETGEAR lifetime warranty
Radio access point
13.3 cm
17.3 cm
3.5 cm
240 g
United Kingdom
External
Wireless
Remote Management Protocol
SNMP 1, SNMP 2
Frequency Band
2.4 GHz
Status Indicators
Power, test mode, WLAN, LAN
Auto-sensing per device, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, hidden SSID, wireless bridge mode, rogue access point detection, ceiling mountable, dual-stream (2x2)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Gain Level
3 dBi
1 x 1000Base-T - RJ-45 , 2 x aerial
Vertical stand
1 x network cable
Mounting Kit
Included
PoE
External power adapter
4 Watt
Software Included
Drivers & Utilities
