The NETGEAR WAC730 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.3 Gbps (450 Mbps for 2.4GHz and 1.3 Gbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC730 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
Robust security
Equipped with a suite of encryption algorithms including 128-bit WEP, 152-bit WEP, 64-bit WEP, PEAP, SSL, TLS, TTLS, WPA, and WPA2, this access point ensures a secure wireless communication environment, safeguarding sensitive data against unauthorized access. -
High-speed connectivity
With an aggregate throughput of 1.75 Gbps, combining 450 Mbps at 2.4 GHz and 1.3 Gbps at 5 GHz, the device offers high-speed data transmission, facilitating seamless streaming and efficient data handling for business operations. -
Versatile networking features
Supports multiple SSID support, VLAN, and Wi-Fi Multimedia (WMM) support, enhancing network management and prioritization of data, voice, and video traffic, ensuring optimal performance across various applications. -
Comprehensive management protocols
Features a wide range of remote management protocols including CLI, HTTP, SNMP 1, SNMP 2c, SSH, and Telnet, allowing for flexible and efficient device management and monitoring. -
Flexible deployment options
Thanks to Power over Ethernet (PoE) support and external form factor, this wireless access point can be easily installed in various environments, reducing the need for additional power cables and offering a clutter-free setup.
- NETGEAR Business 3 x 3 Dual Band Wireless-AC Access Point WAC730 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Aggregate throughput: 1.75 Gbps , Maximum throughput (2.4 GHz): 450 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
- Included Accessories
- Wall mounting kit, ceiling mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- 19.7 cm x 19.7 cm x 4 cm
- 726 g
- NETGEAR lifetime warranty
- 19.7 cm
- 19.7 cm
- 4 cm
- 726 g
- Form Factor
- External
- Connectivity Technology
- Wired
- Bonjour
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Status Indicators
- Power, LAN, wireless, link/activity
- VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, LLDP support, 3T3R MIMO technology, 802.1x authentication, Transmit Power Control (TPC)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- External detachable and internal
- 1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 3 x aerial - RP-SMA
- Cables Included
- 1 x network cable
- PoE
- Limited warranty - lifetime
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.93 |
