The NETGEAR ProSafe 16-AP Wireless Management System is an easy to use appliance to simplify the set up and management of wireless networks. Supporting up to 16 access points, the WMS5316 Wireless Management System provides a single location to configure and manage the entire wireless network. Designed for growing companies who don't want the complexity and cost of full wireless controllers, the WMS5316 Wireless Management System delivers centralized management, load balancing, RF management, and guest access via an intuitive interface. Priced far below a full wireless controller, the WMS5316 Wireless Management System provides significant time savings and simplifies the deployment and management of a wireless network.
Mimicking the set up process of a single access point, the easy to use WMS5316 Wireless Management System enables even novice users to adopt a centralized management architecture for up to 16 access points. With automatic discovery of all supported access points in the network, the WMS5316 Wireless Management System speeds the configuration of a the wireless network. Automatic Radio Frequency (RF) management and channel selection takes care of optimizing the access points in the network for maximum connectivity, without intervention from the network administrator. A single entry of wireless parameters and security settings can then be pushed out to all of the access points, enabling a fully functional wireless network in minutes.
The WMS5316 Wireless Management System monitors the wireless network to ensure optimal performance and respond to changes in the RF environment. It will automatically re-assign channels and adjust RF parameters for maximum connectivity. If enabled, load-balancing on ProSafe Access Points can ensure that no single access point is overloaded continuously, by diverting clients to nearby access points. By actively managing the wireless network, the WMS5316 Wireless Management System provides an improved wireless experience without any IT staff having to lift a finger.
By centrally configuring all access points in the network, the WMS5316 Wireless Management System ensures identical security settings throughout the coverage area so that clients, guests and unwanted intruders all get appropriate access or denial to network resources. Setting up WPA2 encryption keys to keep traffic safe from prying eyes and MAC authentication lists to only allow approved devices on the wireless network can be done once and sent out to the entire network. When used with ProSafe Access Points, the WMS5316 Wireless Management System can configure a guest SSID to allow visitors safe access to the Internet without allowing visibility to company files or resources. Additionally, 802.1x network authentication can be applied for further verification of clients' rights to be on the network. Rogue AP detection will find all access points in the area, enabling administrators to take appropriate actions. The WMS5316 Wireless Management System with central management simplifies the process of deploying a secured wireless network.
Supporting a wide portfolio of standard NETGEAR access points, the WMS5316 Wireless Management System enables customers to select the right access points for their needs, even mixing models to provide the right coverage, as well as an upgrade path as technology changes. The access points retain their standalone capabilities and do not require a conversion to be managed by the WMS5316 Wireless Management System. Supported models include SOHO-class 802.11G access points as well as professional caliber dual band 802.11N access points.
Easy to use wireless network management for small and medium networks
The NETGEAR ProSafe 16-AP Wireless Management System is an easy to use appliance to simplify the set up and management of wireless networks. Supporting up to 16 access points, the WMS5316 Wireless Management System provides a single location to configure and manage the entire wireless network. Designed for growing companies who don't want the complexity and cost of full wireless controllers, the WMS5316 Wireless Management System delivers centralized management, load balancing, RF management, and guest access via an intuitive interface. Priced far below a full wireless controller, the WMS5316 Wireless Management System provides significant time savings and simplifies the deployment and management of a wireless network. -
Deployment
Mimicking the set up process of a single access point, the easy to use WMS5316 Wireless Management System enables even novice users to adopt a centralized management architecture for up to 16 access points. With automatic discovery of all supported access points in the network, the WMS5316 Wireless Management System speeds the configuration of a the wireless network. Automatic Radio Frequency (RF) management and channel selection takes care of optimizing the access points in the network for maximum connectivity, without intervention from the network administrator. A single entry of wireless parameters and security settings can then be pushed out to all of the access points, enabling a fully functional wireless network in minutes. -
Management
The WMS5316 Wireless Management System monitors the wireless network to ensure optimal performance and respond to changes in the RF environment. It will automatically re-assign channels and adjust RF parameters for maximum connectivity. If enabled, load-balancing on ProSafe Access Points can ensure that no single access point is overloaded continuously, by diverting clients to nearby access points. By actively managing the wireless network, the WMS5316 Wireless Management System provides an improved wireless experience without any IT staff having to lift a finger. -
Security
By centrally configuring all access points in the network, the WMS5316 Wireless Management System ensures identical security settings throughout the coverage area so that clients, guests and unwanted intruders all get appropriate access or denial to network resources. Setting up WPA2 encryption keys to keep traffic safe from prying eyes and MAC authentication lists to only allow approved devices on the wireless network can be done once and sent out to the entire network. When used with ProSafe Access Points, the WMS5316 Wireless Management System can configure a guest SSID to allow visitors safe access to the Internet without allowing visibility to company files or resources. Additionally, 802.1x network authentication can be applied for further verification of clients' rights to be on the network. Rogue AP detection will find all access points in the area, enabling administrators to take appropriate actions. The WMS5316 Wireless Management System with central management simplifies the process of deploying a secured wireless network. -
Access points
- NETGEAR 16-AP Wireless Management System WMS5316 - network management device
- Network management device
- Form Factor
- External
- Localisation
- Europe
- RAM
- 512 MB
- Flash Memory
- 64 MB
- Ports Qty
- 4
- Data Link Protocol
- Capacity
- Manageable access points: 16
- Power
- AC 120/230 V (50/60 Hz)
- 33 cm x 20.9 cm x 4.3 cm
- 2.1 kg
- NETGEAR lifetime warranty
- 33 cm
- 20.9 cm
- 4.3 cm
- 2.1 kg
- Localisation
- Europe
Processor / Memory / Storage
- RAM
- 512 MB
- Flash Memory
- 64 MB
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wired
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, SSH
- Capacity
- Status Indicators
- Port transmission speed, power, test mode, link/activity
- Auto-sensing per device, load balancing, auto-uplink (auto MDI/MDI-X), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, DHCP server, rogue access point detection
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.1x
- 4 x 1000Base-T - RJ-45 , 1 x USB - Type A
- Cables Included
- 1 x network cable
- FCC Class A certified, RoHS, WEEE
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 45 °C
