NETGEAR Open Source RangeMax Wireless Gigabit Router USB
Quicklinx: 6MBBWS00 Mfr#: WNR3500L-100UKS
  • IEEE 802.11n (draft 2.0)
Marketing description is not available.
NETGEAR RangeMax WNR3500L - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
HTTP
Firewall protection, NAT support, SPI, DoS attack prevention, VPN passthrough, event log, QoS, WPS, DHCP server
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
17.2 cm x 3.9 cm x 22.6 cm
0.56 kg
Microsoft Certification
Compatible with Windows 7
UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK
MIPS 533 MHz
RAM
32 MB
Flash Memory
8 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
Directivity
Omni-directional
External power adapter
Vertical stand
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
17.2 cm
3.9 cm
22.6 cm
0.56 kg
