NetGear Nighthawk X4S AC2600 Smart WiFi Router
Quicklinx: BW80WS00 Mfr#: R7800-100UKS
  • IEEE 802.11n
Nighthawk X4S smart Wi-Fi router with MU-MIMO technology delivers Wi-Fi to multiple devices simultaneously for faster speeds. Stream 4K content in pristine quality with high bandwidth. Enjoy outstanding Wi-Fi speeds, a powerful processor, and QoS, delivering smoother streaming and gaming by prioritizing applications and devices.
  • Multi-user MIMO (MU-MIMO)
    Using multi-user MIMO technology, this NETGEAR router can stream data to multiple devices simultaneously. With MU-MIMO, your Wi-Fi network can deliver faster throughput to every MU-MIMO connected device. That means faster downloads and smoother streaming for your devices.
  • Dynamic Quality of Service (QoS)
    If you like gaming and streaming videos, then you can benefit from Dynamic Quality of Service (QoS). Dynamic QoS automatically prioritizes bandwidth to latency sensitive applications like online gaming and video streaming by recognizing application and device information as well as bandwidth needs. Dynamic QoS will also ensure that lower priority applications like file downloads will never get completely stopped.
NETGEAR Nighthawk X4S R7800 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
NAT support, VPN support, DoS attack prevention, print server, IPv6 support, parental control, QoS, WPS, FTP server, ReadySHARE, DLNA Media Server, SPIF, Beamforming+, MU-MIMO technology, SmartConnect Technology, Circle Smart Parental Controls
28.5 cm x 18.5 cm x 5 cm
840 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8, Windows 10
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2.53 Gbps
Encryption Algorithm
WPA, WPA2, WPA2-PSK
1 x 1.7 GHz
RAM
512 MB
Flash Memory
128 MB
Built-in Devices
Led panel
Line Properties
Line Coding Format
256 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Storage: 1 x eSATA - 7 pin external Serial ATA
Aerial
Antenna Qty
4
External power adapter
1 x network cable
United Kingdom
28.5 cm
18.5 cm
5 cm
840 g
