Jump up to Wireless N without leaving 11g behind.
Backward compatible to 802.11g devices, the WNAP210 simultaneously provides faster wireless networking for 802.11n devices - up to 10x the coverage and 15x the speed.
Advanced Speed and Range with Comprehensive Internet Security
- Up to 10x the coverage and 15x the speed of 802.11g networks
- Backward compatible to 802.11g devices while simultaneously providing faster wireless networking for 802.11n devices
- Security features include WPA, WPA2, rogue AP detection and 802.1x with RADIUS support
- Can run on 802.3af PoE for easy placement in optimal locations- desktop, wall-mount or ceiling
- Internal antennas for optimized antenna configuration without user guesswork
- Comprehensive SNMP functionality for advanced network management
- Deploy over large areas with point-to-point and point-to-multipoint bridging over large areas with Wireless Distribution System (WDS)
- Mounting kit provides for wall or ceiling placements
- NETGEAR Wireless-N WNAP210 v2 - radio access point Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- Included Accessories
- Vertical stand
- Power Over Ethernet (PoE) Supported
- PoE
- 22.35 cm x 15.32 cm x 2.8 cm
- 410 g
- NETGEAR lifetime warranty
- 22.35 cm
- 15.32 cm
- 2.8 cm
- 410 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, test mode, WLAN, LAN
- Auto-sensing per device, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, hidden SSID, wireless bridge mode, rogue access point detection
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Aerial
- Antenna
- Internal
- 1 x 1000Base-T - RJ-45
- Vertical stand
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- PoE
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
