The NETGEAR ProSafe line of business networking products offers a wide array of easy-to-use, professional-grade switching, wireless, software and security solutions. ProSafe products provide an abundance of intelligent, innovative and practical features, addressing the unique requirements of business networks.
- NETGEAR ProSafe FVS318N - wireless router - 802.11b/g/n - desktop
- Wireless router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Performance
- Throughput: 95 Mbps
- Capacity
- IPSec VPN tunnels: 12 , Concurrent SSL VPN sessions: 5 , Concurrent connections: 6000
- TCP/IP, UDP/IP, NTP, ICMP/IP, PPPoE
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Firewall protection, DMZ port, routing, DHCP support, NAT support, IPv6 support, Quality of Service (QoS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support, port triggering, DHCP client
- IEEE 802.11b, IEEE 802.11g, X.509, IEEE 802.11n
- 19 cm x 12.5 cm x 3.5 cm
- 590 g
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 256-bit AES
- Authentication Method
- X.509 certificates, Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11g, X.509, IEEE 802.11n, ICSA Firewall certified, X.509, VPNC certified
- Processor
- 1 x 300 MHz
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Status Indicators
- Link/activity
- LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- Software Included
- ProSafe VPN Client
- 19 cm
- 12.5 cm
- 3.5 cm
- 590 g
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
