NetGear ProSAFE WC7600 Premium Wireless Controller
LIFETIME WARRANTY
Quicklinx: 9GZCWS00 Mfr#: WC7600-10000S
Centralized wireless management for today and future ProSAFE wireless Access Point portfolio, from the entry level single band WNAP210/WNAP320/WN370 to dual band business class WNDAP360/350, and extending up to premium grade 3x3 WNDAP660/620 and supporting future 802.11ac AP’s. The WC7600 is simple to configure with friendly user interface and wizard setup, intuitive to manage with dashboard and comprehensive monitoring statistics, and cost effective. The WC7600 is developed specifically for small and medium enterprise, K-12 education, and small and mid-size healthcare looking to deploy a fully managed and redundant wireless solution. With simplicity and ease of use in mind, the WC7600 is purpose built to bridge the gap between the basic standalone Access Point and the complex and difficult to manage high end wireless controllers. The WC7600 is ideal for IT challenged customers looking for a solution that automatically configure and tune the wireless network for optimal performance. The WC7600 comes fully equipped with enterprise grade features such as comprehensive wireless security (WPA, WPA2, Radius, LDAP, Rogue AP protection), guest access, and full networking functionality from embedded DHCP server, VLAN on wired and wireless networks, to full Quality of Service for different class of users. The WC7600 is a fully redundant hardware (redundant fans, hot swappable power supply).
  • Enhanced connectivity
    With dual SFP+ connectors, a RJ-45 for 1000Base-T management, a DB-9 connector, and a Type-A USB 2.0 port, this device offers a variety of connectivity options for different network needs, ensuring high-speed and efficient network management.
  • Robust security
    Featuring multiple authentication methods including Active Directory, LDAP, and SSID with encryption algorithms like TKIP and WEP, the WC7600 Premium Wireless Controller provides a secure networking environment, safeguarding your data from unauthorized access.
  • High reliability
    Designed for continuous operation, the WC7600 boasts an impressive MTBF of 664,072 hours, minimizing downtime and ensuring your network remains operational when you need it most.
  • Advanced networking features
    Supports DHCP server, IPv4 and IPv6, RADIUS, Wi-Fi Multimedia (WMM), auto-negotiation, auto-sensing per device, load balancing, and rogue access point detection, making it a versatile tool for managing complex wireless networks.
  • Power redundancy
    With hot-plug capability and power redundancy, the internal power supply ensures your network remains live without interruption, even in the event of a power supply failure.
NETGEAR WC7600 Premium Wireless Controller - network management device
Network management device
External - 1U
Worldwide (excluding China)
Gigabit Ethernet, 10 Gigabit Ethernet
Manageable access points: 50 , Maximum number of access points (per cluster): 150 , BSSIDs: 144 , Concurrent stations per cluster: 6000 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
AC 100/230 V
Power Redundancy
44 cm x 43 cm x 4.3 cm
7.57 kg
NETGEAR lifetime warranty
Height (Rack Units)
1U
44 cm
43 cm
4.3 cm
7.57 kg
External
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
Routing Protocol
CIDR
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, TFTP, SSH
Status Indicators
Power, status, fan
Auto-sensing per device, auto-negotiation, load balancing, LDAP support, VLAN support, Syslog support, stackable, IPv6 support, SNTP support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Access Control List (ACL) support, RADIUS support, roaming function, DHCP server, IPv4 support, rogue access point detection, tagged VLAN, Captive Portal
Encryption Algorithm
DES, Triple DES, IKE, TKIP, WPA-PSK, AES-CCMP, AES-CCM, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, AES-CBC, 128-bit SSL, 1024-bit RSA, 2048-bit RSA, TLS 1.1, WEP
Authentication Method
X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
MTBF
664,072 hours
Installed Qty
2
Max Supported Qty
2
Power Redundancy
AC 100/230 V
82.3 Watt
Power Provided
165 Watt
Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days
45 °C
10 - 90%
9GZC C2G 2m USB 2.0 A/B Cable - Black In Stock £4.04
Resources
The following resources are available for the NetGear ProSAFE WC7600 Premium Wireless Controller
