The N900 Wireless Dual Band Gigabit Router WNDR4500v2 provides you with an easy and secure way to set up a home network with fast access to the Internet over a high-speed digital subscriber line (DSL). It is compatible with all major DSL Internet service providers, lets you block unsafe Internet content and applications, and protects the devices that you connect to your home network.
- NETGEAR WNDR4500v2 - wireless router - 802.11a/b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- TCP/IP, PPPoE, DHCP, SMB
- Routing Protocol
- RIP-1, RIP-2
- DHCP support, dynamic DNS server, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Live Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- Power
- AC 230V (50 Hz)
- 22.3 cm x 15.3 cm x 3.1 cm
- 0.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Routing Protocol
- RIP-1, RIP-2
- Encryption Algorithm
- 128-bit WEP, 40-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, CISPR 22, FCC Part 15 B
- Status Indicators
- Power, WLAN, WAN, LAN, USB, WPS
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Voltage Required
- AC 230V (50 Hz)
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 22.3 cm
- 15.3 cm
- 3.1 cm
- 0.5 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.01 |
