The new ProSAFE M6100 Chassis series is set to shake up how SMBs deploy high performance, highly resilient, fully redundant and future proof switched networks from the Core to the Edge - without hurting or exhausting IT budgets. The NETGEAR LAN Access and Aggregation Chassis M6100 series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB core deployments, as well as 1G / 10G mixed infrastructures in server rooms. Innovative distributed fabric provides non-stop forwarding resiliency and world-class availability - including passive backplane, hitless failover, redundant fabric and redundant management - without having to pay the exorbitant acquisition and maintenance costs associated by other networking vendors in this class.
Designed for use at the center of a small to mid-sized organization, or as an aggregate or access solution in a larger campus or mid-sized enterprise branch network, the application scenarios for the M6100 are both wide and diverse.
No single point of failure with management and power backup and distributed link aggregation across multiple chassis arrangements.
No performance compromise. With up to 10 x performance of fixed stackable solutions with similar port counts, value performance ratios are unrivaled.
Decide on the port count and speeds you need, from 144 Gigabit ports through to 72 10 Gigabit ports, or a combination of both.
Chassis Standards Redefined
The new ProSAFE M6100 Chassis series is set to shake up how SMBs deploy high performance, highly resilient, fully redundant and future proof switched networks from the Core to the Edge - without hurting or exhausting IT budgets. The NETGEAR LAN Access and Aggregation Chassis M6100 series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB core deployments, as well as 1G / 10G mixed infrastructures in server rooms. Innovative distributed fabric provides non-stop forwarding resiliency and world-class availability - including passive backplane, hitless failover, redundant fabric and redundant management - without having to pay the exorbitant acquisition and maintenance costs associated by other networking vendors in this class. -
All in one solution
Designed for use at the center of a small to mid-sized organization, or as an aggregate or access solution in a larger campus or mid-sized enterprise branch network, the application scenarios for the M6100 are both wide and diverse. -
Distributed fabric, passive backplane
NO single point of failure with management and power backup and distributed link aggregation across multiple chassis arrangements. -
480Gbps inter-module backplane performance
No performance compromise. With up to 10 x performance of fixed stackable solutions with similar port counts, value performance ratios are unrivaled. -
Gigabit and 10G blades offering deployment flexibility for today and tomorrow's needs
- NETGEAR XCM8944F - switch - 44 ports - plug-in module
- Switch - 44 ports
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Ports
- 40 x SFP + 2 x 10Gb Ethernet + 2 x 10 Gigabit SFP+
- 24 MB packet buffer
- 48.26 cm x 32.35 cm x 4.05 cm
- 3.38 kg
- NETGEAR lifetime warranty
- Switch - 44 ports
- Enclosure Type
- Plug-in module
- Subtype
- Gigabit Ethernet
- Ports
- RAM
- 1 GB
- Flash Memory
- 64 MB
- Status Indicators
- Port transmission speed, status, link/activity, supervisor
- 40 x 1000Base-X SFP , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A
- 150 Watt
- Cables Included
- 2 x console cable
- MTBF
- 694,849 hours
- 48.26 cm
- 32.35 cm
- 4.05 cm
- 3.38 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
C2G 2m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua | In Stock | £12.40 |
