For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-speed connectivity
Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures efficient data transfer and high-speed connectivity for all your computing needs. -
Durable design
Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection and resist corrosion, ensuring your network setup remains uninterrupted. -
Universal compatibility
With its T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for connecting a wide range of devices. Whether for home or office use, it ensures a stable and secure connection every time.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - blue
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 2 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Blue
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 2 m
 - Blue
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
