NetGear EX6200-100UKS AC1200 Wi-Fi Range Extender
Quicklinx: 9D3TWS00 Mfr#: EX6200-100UKS
  • IEEE 802.11n
The NETGEAR EX6200 AC1200 Simultaneous Dual-Band Wireless-AC Range Extender boosts your existing network range and speed, delivering Wireless-AC dual-band WiFi up to 1200Mbps. The high-power design of this range extender provides ultimate range, while the dual core processor enables maximum WiFi performance. The NETGEAR EX6200 works with any standard WiFi router and is ideal for very large homes and frustration free HD video streaming and gaming.
Simultaneous Dual-Band Wireless-AC 802.11ac up to 1200Mbps
5 x Gigabit Ethernet Ports: Connect up to 5 wired devices
Amplified high-power design for ultimate wireless range/coverage
Dual core processor for max WiFi performance
Ideal for use with iPads, smartphones, laptops & more
Wirelessly share and access USB storage connected to the USB 3.0 port
Beamforming+: Focuses WiFi signals directly to wireless devices Wireless Printing - Print documents & photos to any USB printer
FastLane Technology uses both WiFi bands for super high-speed connection
WiFi Analytics App
How strong is your WiFi signal? Use the NETGEAR WiFi Analytics app and get advanced analytics to optimise your existing or newly extended WiFi network. Check your network status, WiFi signal strength, identify crowded WiFi channels & much more!
Standard Warranty: 2-Years
  • Wi-Fi
    Create faster dual band Wi-Fi access with 802.11ac technology up to 1200 Mbps.
  • Ultimate range
    700 mW high-power amplifiers and high-gain 5 dBi antennas for maximum Wi-Fi coverage.
  • READYSHARE USB
    Wirelessly share and access USB storage connected to the USB 3.0 port.
  • Blazing fast CPU
    Powerful dual core ARM A9 processor enables maximum Wi-Fi throughput at Gigabit speed.
  • Beamforming+
    Focuses Wi-Fi signals directly to wireless devices for more reliable connections.
  • 5 Gigabit Ethernet ports
    Connect up to 5 wired devices like Blu-ray players, game consoles, smart TVs or streaming players to your Wi-Fi network.
  • Wireless printing
    Print documents and photos to any USB printer connected to the Wi-Fi range extender.
  • FastLane technology
    Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming and gaming.
NETGEAR AC1200 WiFi Range Extender EX6200 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
ARM9
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Vertical stand
17.4 cm x 3.1 cm x 25.2 cm
302 g
17.4 cm
3.1 cm
25.2 cm
302 g
United Kingdom
Processor / Memory / Storage
Processors Installed
ARM9
External
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, on/off switches, FastLane Technology
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
5 dBi
5 x 1000Base-T - RJ-45 , 1 x USB 3.0
Vertical stand
External power adapter
Limited warranty - 2 years , Limited warranty - phone consulting - 90 days
9D3T C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
