![]() | Wireless ConnectivityThe DG834G 54 Mbps Wireless ADSL modem router provides continuous, untethered access to network resources and the Internet. The DG834G allows you to share your hi-speed ADSL broadband connection wirelessly with all the desktop PC’s, laptops and games consoles in the household or small office. A built-in 4 port switch also enables you to connect some computers using cables if you prefer. |
![]() | Safe and SecureThe built-in True Firewall features Stateful Packet Inspection (SPI) and Denial of Service (DOS), which operate as your first line of attack against intruders. The DG834G provides both WEP and WPA-PSK wireless encryption standards to protect your network from eavesdroppers and bandwidth pinchers! Content filtering lets you control access to inappropriate websites and limit usage by time of day. To be ultimately secure you can limit access to designated computers using their unique ID, called a MAC address. |
![]() | Easy to Set-upThe DG834G 54 Mbps wireless router is simple to use – it plugs directly into your ADSL line, no need for a separate modem. Set-up could not be easier; NETGEAR’s Smart Wizard install assistant automatically detects and makes the best connection to your ISP (Internet Service Provider). It is also easy to change the settings of your DG834G wireless router via a web-browser interface. |
- NETGEAR DG834Gv5 - wireless router - DSL modem - 802.11b/g - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 54 Mbps
- Capacity
- IPSec VPN tunnels: 5
- TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- DMZ port, auto-sensing per device, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, E-mail alert, Wireless Distribution System (WDS) support, URL filtering, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, DNS proxy, Green Ethernet
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED
- Environmental Standards
- ENERGY STAR Qualified
- 17.5 cm x 11.9 cm x 2.8 cm
- 300 g
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 54 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- ADSL, ADSL2+
- Protocols & Specifications
- ITU G.992.1 (G.DMT) Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
- Power Device
- External power adapter
- ENERGY STAR Certified
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 17.5 cm
- 11.9 cm
- 2.8 cm
- 300 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
Customer reviews
Write a review for the NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g here!
Very Pleased
Reviewed by Anonymous Review Posted 07/07/2005
Was looking for a reliable router and stubled on this, and found that it works like a dream. I can walk around the house without ever losing the connection. Brought with a Dabsvalue PCMICIA card, slightly more expensive but worth it. Works with tiscali so im happy.
Overall
Ease of use
Value for money
Easy set-up great looking product
Reviewed by Anonymous Review Posted 22/02/2004
Quick delivery from dabs, no hastle. Got the unit up and running in ten minutes and found connection speeds excellent throughout my home, I also purchased the WG511 PC card and WG121 USB adapter for my laptop and desktop and found that set-up on these were also very straight forward. I purchased on a recommendation from Digital Home Magazine where the DG834G had recently won an award.
Overall
Ease of use
Value for money
Hassle Free Wireless Connectivity!
Reviewed by Anonymous Review Posted 27/07/2005
Reviewed following six very successful months use by a non-techie user with OneTel broadband. I originally bought this router with the sole intention of freeing up my Dell Centrino lap top. Within a week I’d bought a USB stick for my antiquated Siemens Xpert desktop (Dabs Value - EW-7317UG). The unit was pre-installed with the latest firmware and has been absolutely problem free. Tying MAC addresses down was easy, using the WEP feature was easy. This router is currently supporting the Dell laptop, the same antiquated Siemens desktop, a Palm T3 with wi-fi card and just lately, two Apple iBooks belonging to visiting friends. Really hassle free!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
