NetGear N600 Wireless-N Dual Band Gigabit ADSL2+ Modem Router
AVOIDS INTERFERENCE AND ENSURES TOP SPEEDS
Quicklinx: 7FF5WS00 Mfr#: DGND3700-100UKS
  • IEEE 802.11n
The NETGEAR N600 Wireless Dual Band Gigabit ADSL2+ Modem Router is the Ultimate Integrated DSL Networking Gateway. It offers concurrent dual band technology which avoids interference and ensures top speeds and the greatest range for demanding applications, such as streaming HD video and multiplayer gaming. Complete with a built-in DSL modem, it is compatible with all major DSL Internet service providers.All-in-one -- Built-in ADSL2+ modem and WAN Gigabit Ethernet port for cable/fiber combined with a wireless router create the
Ultimate Integrated Home Gateway
  • Concurrent Dual band -- Eusuring top speeds and the greatest range while minimizing interference
  • Faster multimedia streaming -- Provides Wireless-N speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications
  • Shared storage -- Two (2) ports for ReadySHARE® USB Storage Access provides fast and easy shared access to an external USB storage device
  • Live Parental Controls -- Keeps your Internet experience safe
  • Guest network access -- Provides separate security and access restrictions for guests using the network
  • Secured connection -- Push 'N' Connect ensures a quick and secure network connection
  • Broadband usage meter -- Monitors Internet traffic and sends customized reports to help keep costs under control
  • Easy installation -- Connect to PC and open your browser to install
  • Compatibility -- Compatible with all major ADSL Internet service providers (ISPs)
The Netgear Difference
  • Powerful Dual-Core processor
  • ReadySHARE® USB Storage Access
  • Live Parental Controls - Free!
  • Best wireless speed and range
  • Advanced Quality of Service
The Ultimate Home Gateway
  • Use with ADSL2+ modem (built-in) or cable/fiber modem (through Gigabit Ethernet)
  • DLNA® -- stream videos, photos, and music to your HDTV
  • Gigabit -- fast wired connections for gaming and video
  • Simultaneous Dual Band -- avoid interference for streaming media and online gaming
Advanced Features
  • Live Parental Controls with flexible and customizable filter settings
  • Simultaneous Dual Band -- 2.4 GHz and 5 GHz operation
  • Two (2) ports for ReadySHARE® USB Storage Access -- supports FAT16/32, NTFS Read/Write
  • DLNA® -- stream media to DLNA media players
  • Multiple SSID guest networks (separate security and access restrictions)
  • Broadband usage meter measures Internet usage
  • Power and Wi-Fi on/off buttons
Package Contents
  • N600 Wireless Dual Band Gigabit Router (DGND3700)
  • Stand
  • Ethernet cable
  • NETGEAR Genie™ installation CD
  • Power adapter, localized to country of sale
  • Broadband (cable, DSL) Internet service and modem with Ethernet connection
  • 2.4 or 5.0 GHz 802.11a/b/g/n specification wireless adapter or an Ethernet adapter and cable for each computer
  • Microsoft® Windows® 7, Vista®, XP, 2000, Mac OS®, UNIX®, or Linux®
  • Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari 1.4 or higher
  • Use with an N600 Wireless Dual Band USB Adapter (WNDA3100 for maximum performance)
Standards
  • IEEE 802.11 b/g/n 2.4 GHz
  • IEEE 802.11 a/n 5.0 GHz
  • Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports
  • Two (2) USB 2.0 ports
  • One (1) ADSL2+ port
Performance
  • All-in-one -- High Speed ADSL2+ Modem (built-in) and WAN Gigabit Ethernet port for cable/fiber
  • Powerful Dual Core (400 MHz each) processor
  • High speed access to external USB storage using 2 USB 2.0 ports
  • Memory: 128 MB Flash and 128 MB RAM
  • Five (5) (1 WAN, 4 LAN) Gigabit Ethernet ports
  • Advanced Quality of Service (QoS)
Security
  • Wi-Fi Protected Access® (WPA/WPA2 -- PSK) and WEP
  • Double firewall protection (SPI and NAT firewall)
  • Denial-of-service (DoS) attack prevention
Ease of Use
  • Easy installation -- connect to PC and open your browser to install
  • Push 'N' Connect using Wi-Fi Protected Setup® (WPS)1
Physical Specifications
  • Dimensions: 223 x 153 x 31 mm (8.8 x 6.0 x 1.2 in)
  • Weight: 0.5 kg (1.2 lb)
NETGEAR Green Features
  • Power On/Off Button
  • 80% Recycled Packaging
  • CEC (California Efficiency)
  • RoHS
  • WEEE
  • Wireless On/Off Button
  • All-in-one feature
    It features built-in ADSL2+ modem and WAN Gigabit Ethernet port for cable/fiber combined with a wireless router create the ultimate integrated home gateway.
  • Concurrent dual band
    It ensures top speeds and the greatest range while minimizing interference.
    It provides wireless-N speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications.
  • Shared storage
    Two ports for ReadySHARE USB storage access provides fast and easy shared access to an external USB storage device.
  • Live parental controls
    It keeps your Internet experience safe.
    It provides separate security and access restrictions for guests using the network.
    It can push 'N' connect ensures a quick and secure network connection.
    It monitors Internet traffic and sends customized reports to help keep costs under control.
  • Easy installation
    You can connect it to PC and open your browser to install it.
NETGEAR DGND3700 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Remote Management Protocol
HTTP
Firewall protection, NAT support, SPI, DoS attack prevention, firmware upgradable, QoS, WPS, Multiple SSID support, ReadySHARE, Live Parental Controls, Push ‘N’ Connect button, broadband usage meter, DLNA Media Server
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED
22.3 cm x 15.3 cm x 3.1 cm
0.5 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/ME/XP/Vista/7
United Kingdom
1-year warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, RoHS, WEEE, CEC
400 MHz
RAM
128 MB
Flash Memory
128 MB
Communications
DSL modem
ADSL, ADSL2, ADSL2+
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
Vertical stand
1 x network cable , 1 x phone cable
United Kingdom
Software Included
NETGEAR Genie
22.3 cm
15.3 cm
3.1 cm
0.5 kg
Limited warranty - 1 year
7FF5 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
Resources
The following resources are available for the NetGear N600 Wireless-N Dual Band Gigabit ADSL2+ Modem Router
