NETGEAR LB1111 Wireless Cellular Modem GSM, UMTS, LTE, DC-HSPA+
Quicklinx: CDWMWS00 Mfr#: LB1111-100EUS
The NETGEAR 4G LTE Modem LB1111 is a simple LTE connectivity solution for all your devices and equipment, and the Power-over-Ethernet option is ideal for remote locations without the need to plug in a power adapter. Simply connect this LTE Modem directly to your PoE-supported equipment to provide instant 4G LTE broadband connection.
  • Flexible connectivity
    The NETGEAR LB1111 wireless cellular modem offers a variety of connectivity options including LTE, GSM, and UMTS, ensuring reliable access to 4G networks for high-speed Internet wherever you are.
  • Easy installation
    With an external detachable antenna and support for Power over Ethernet (PoE), setting up the NETGEAR LB1111 is straightforward, allowing for flexible placement and easy integration into your existing network infrastructure.
  • Robust management features
    Equipped with features like a DHCP server, DMZ port, and remote management via TR-069, the NETGEAR LB1111 provides comprehensive control over your network, ensuring secure and efficient operation.
NETGEAR LB1111 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
Europe
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
AC 230V
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
12 cm x 9.9 cm x 3.1 cm
150 g
External
Built-in Devices
Led panel
Europe
Modem
Bus
Gigabit Ethernet
Wireless
Max Transfer Rate
150 Mbps
Antenna
External detachable
Antenna Qty
1
Remote Management Protocol
TR-069
DMZ port, power over Ethernet (PoE), DHCP server
1 x 1000Base-T - RJ-45
SIM Card Supported
Regular (mini-SIM) x 1
1 x network cable
Power adapter
AC 230V
12 cm
9.9 cm
3.1 cm
150 g
0 - 90% (non-condensing)
CDWM C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
CDWM C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
