For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
Potent
Moves huge files fast! Features up to eight high-speed, auto-switching 10/100/1000 Mbps Ethernet connections. And because Gigabit Ethernet is a full duplex standard, you get up to 2000 Mbps on each port. The GS100 Series provides jumbo frame support up to 9,000 byte frames. -
Capable
Integrates 10-, 100-, and 1000-Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, and Auto Uplink technology automatically adjusts for straight-through or crossover cables. -
Trim
Sized to save space, this sturdy metal switch is compact and fits easily on a desk or mounts on a wall, making it ideal for home and small office environments. -
Easygoing
LEDs embedded in RJ-45 jacks make for easy monitoring. Provides noiseless operation. Supports PC or Mac O/S (operating system).
- NETGEAR GS105 - switch - 5 ports
- Switch - 5 ports
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- MAC Address Table Size
- 2K entries
- Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3p
- 9.4 cm x 10 cm x 2.7 cm
- 0.3 kg
- Localisation
- United Kingdom
- NETGEAR lifetime warranty
- Switch - 5 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- 2K entries
- RAM
- 128 KB
- Status Indicators
- Collision status, port transmission speed, port duplex mode, power, link OK, link/activity
- 5 x 10/100/1000 Base-T RJ-45
- Power Device
- External power adapter
- Mounting Kit
- Included
- FCC Class B certified, C-Tick, VCCI Class B ITE
- Localisation
- United Kingdom
- 9.4 cm
- 10 cm
- 2.7 cm
- 0.3 kg
- 0 °C
- 50 °C
- Up to 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.64 |
Customer reviews
Write a review for the NETGEAR GS105 5 Port Gigabit Switch here!
It just works
Reviewed by David. Review Posted 30/11/2007
Another great easy, simple product: you just plug it in and go!
Overall
Ease of use
Value for money
Excellent value, no problems at all.
Reviewed by Anonymous Review Posted 13/07/2007
Plugged straight in between XP Pro and Vista boxes each with Intel PRO1000/GT adapters -> copies 100Mb file in under 10secs. Runs cool & silent, uplinks to 10/100 switch via normal cable.
Overall
Ease of use
Value for money
Fantastic gigabit switch for the price
Reviewed by Nami IT Solutions Ltd. Review Posted 17/08/2007
At Nami IT Solutions Ltd we have been using this Netgear gigabit product range for some time and have never had any issues with any of them so we can happily confirm that this item can be used for almost any network range.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
