NETGEAR GS105 5 Port Gigabit Switch
CONNECTS UP TO 10X FASTER THAN FAST ETHERNET FOR MAXIMUM PERFORMANCE
Customer rating: 5.0* (Write a review)
Quicklinx: 2X1XWS00 Mfr#: GS105UK
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 In Stock
£16.15 ex VAT
£19.38 inc VAT
For a high-speed network on a small scale, nothing delivers likes these compact powerhouses. Equipped with five auto-sensing 10/100/1000 Mbps UTP ports, NETGEAR ProSafe GS105 switches give your network the capacity to handle huge workloads. If your network is configured to support jumbo frames, ProSafe GS105 switches will forward them, as well as honoring priority tags at both the layer 2 and layer 3 level. This means they move very large files across your network instantly, and keep the high priority traffic moving. Packed with ease-of-use features to simplify your networking experience, its trim design makes it an easy fit for a desk or mounted on a wall. The durable metal chassis protects interior working parts and the fanless design results in silent operation. Matched with NETGEAR's thorough testing, the ProSafe GS100 series switches provide long-lasting performance you can count on.
  • Potent
    Moves huge files fast! Features up to eight high-speed, auto-switching 10/100/1000 Mbps Ethernet connections. And because Gigabit Ethernet is a full duplex standard, you get up to 2000 Mbps on each port. The GS100 Series provides jumbo frame support up to 9,000 byte frames.
  • Capable
    Integrates 10-, 100-, and 1000-Mbps devices on the same network. Every port automatically senses the right speed and full/half duplex mode, and Auto Uplink technology automatically adjusts for straight-through or crossover cables.
  • Trim
    Sized to save space, this sturdy metal switch is compact and fits easily on a desk or mounts on a wall, making it ideal for home and small office environments.
  • Easygoing
    LEDs embedded in RJ-45 jacks make for easy monitoring. Provides noiseless operation. Supports PC or Mac O/S (operating system).
NETGEAR GS105 - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
MAC Address Table Size
2K entries
Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3p
9.4 cm x 10 cm x 2.7 cm
0.3 kg
United Kingdom
NETGEAR lifetime warranty
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
2K entries
RAM
128 KB
Status Indicators
Collision status, port transmission speed, port duplex mode, power, link OK, link/activity
5 x 10/100/1000 Base-T RJ-45
External power adapter
Mounting Kit
Included
FCC Class B certified, C-Tick, VCCI Class B ITE
United Kingdom
9.4 cm
10 cm
2.7 cm
0.3 kg
50 °C
Up to 90% (non-condensing)
2X1X C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
2X1X C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.78
2X1X C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Customer reviews
Write a review for the NETGEAR GS105 5 Port Gigabit Switch here!
It just works
Reviewed by David. Review Posted 30/11/2007
Another great easy, simple product: you just plug it in and go!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent value, no problems at all.
Reviewed by Anonymous Review Posted 13/07/2007
Plugged straight in between XP Pro and Vista boxes each with Intel PRO1000/GT adapters -> copies 100Mb file in under 10secs. Runs cool & silent, uplinks to 10/100 switch via normal cable.
  • Overall 5*
  • Ease of use 5*
Fantastic gigabit switch for the price
Reviewed by Nami IT Solutions Ltd. Review Posted 17/08/2007
At Nami IT Solutions Ltd we have been using this Netgear gigabit product range for some time and have never had any issues with any of them so we can happily confirm that this item can be used for almost any network range.
  • Overall 5*
  • Ease of use 5*
Read all 6 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Ports: 5
Managed: No
POE: No
Brand: NETGEAR
