Extend any router's existing Wi-Fi with the Nighthawk X4 AC2200 Wi-Fi Range Extender, delivering speeds up to 2.2Gbps. The powerful and compact X4 increases coverage up to 930 m2 MU-MIMO lets you stream to multiple devices for faster speeds than traditional Wi-Fi, while FastLane technology improves performance using both Wi-Fi bands. High-power amplifiers and internal antenna array increase range for whole home coverage. Boost your Wi-Fi to the Extreme with Nighthawk X4 Wall-plug extender.
                Enhanced connectivityWith dual-band support for both 2.4 GHz and 5 GHz frequencies, the NETGEAR Nighthawk EX7300 ensures a more reliable and less congested Wi-Fi connection. This versatility allows for smoother streaming, gaming, and Internet browsing experiences across a wide range of devices.
                High-speed performanceBoasting a data transfer rate of up to 2200 Mbps, this Wi-Fi range extender is designed to eliminate dead zones and boost your Wi-Fi coverage. It supports MU-MIMO technology, enabling multiple devices to receive high-bandwidth Wi-Fi signals at the same time, without compromising speed.
                Secure wireless networkingThe NETGEAR Nighthawk EX7300 comes equipped with advanced encryption standards including WEP, WPA-PSK, and WPA2-PSK. This ensures your network is safeguarded against unauthorized access and keeps your data secure.
                Easy setup and managementFeaturing Wi-Fi Protected Setup (WPS) and an integrated power plug, the EX7300 is designed for a quick and hassle-free installation process. Its auto-sensing per device feature optimizes connection quality for each connected device, enhancing the overall user experience.
- NETGEAR Nighthawk EX7300 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- 1 GHz
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 8.14 cm x 4.45 cm x 16.1 cm
- 300 g
- 8.14 cm
- 4.45 cm
- 16.1 cm
- 300 g
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- 1 GHz
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 2200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Auto-sensing per device, Wi-Fi Protected Setup (WPS), integrated power plug, MU-MIMO technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
Aerial
- Antenna
- Internal
- 1 x 1000Base-T - RJ-45
- Power Device
- Internal power supply
