The NETGEAR Nighthawk AC1900 Wi-Fi range extender boosts your existing network range & speed, delivering extreme dual band Wi-Fi up to 1900 Mbps. The high-powered amplifiers provide extreme range, while the dual core 1 GHz processor enables maximum Wi-Fi performance. It works with any standard Wi-Fi router & is ideal for HD video streaming & gaming. Get the whole-home connectivity you need for iPads, smartphones, laptops & more.
Boost your existing WiFi
Extend dual band WiFi up to 1900Mbps & reduce interference
External antennas for better WiFi coverage & more speed
5 Gigabit Ethernet Ports - Connect a wired device like Blu-ray player, game console, or smart TV to your WiFi network
Two WiFi Modes - Extend existing WiFi connection or create a new AC WiFi access point
FastLane Technology - Use both WiFi bands to establish one super high-speed connection; ideal for HD streaming & gaming
Extend - Extreme Range & Performance
Extreme dual band WiFi speed - up to 1900Mbps
Dual Core 1GHz processor enables max WiFi performance
3 external antennas for max signal coverage
FastLane technology improves performance using both WiFi bands
Stream - Ultimate Connectivity
5 Gigabit ports to connect wired devices like smart TVs and game consoles
Access Point mode creates a WiFi hotspot using a wired Ethernet connection
USB 3.0 for up to 10x faster access to your stored media
DLNA server to play your media on TVs & game consoles
Access scheduling for parental controls
Mobile - Up To 100% Faster
Whole home WiFi coverage for your mobile devices
Print from an iPad or iPhone - Make any printer AirPrint compatible
Optimize your WiFi network with the WiFi Analytics app for Android
Web browser based settings accessible on most devices
WiFi Analytics App
How strong is your WiFi signal? Use the NETGEAR WiFi Analytics App & get advanced analytics to optimize your existing or newly extended WiFi network. Check your network status, WiFi signal strength, identify crowded WiFi channels & much more!
Extend your Wi-Fi
Say goodbye to those frustrating dead zones and dropped connections with the fastest available Wi-Fi range extender. -
Gaming and streaming
With combined Wi-Fi speeds up to 2.2Gbps, advanced features like MU-MIMO and Smart Connect, you can enjoy gaming and video streaming anywhere in your home. -
Seamless coverage
Stream music, video chat in your kitchen, or play online games in the basement. -
Easy setup and use with the Nighthawk app
With the Nighthawk app, setup takes just minutes, so you can start enjoying better Wi-Fi sooner. You can also see your connected devices, run an Internet speed test, and more from the palm of your hand.
- NETGEAR Nighthawk EX7000 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- 1 GHz
- Ports Qty
- 5
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Vertical stand
- 25.2 cm x 17.4 cm x 3.1 cm
- 654 g
- 2-year warranty
- 25.2 cm
- 17.4 cm
- 3.1 cm
- 654 g
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- 1 GHz
- Form Factor
- External
- Ports Qty
- 5
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1900 Mbps
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Auto-sensing per device, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, FastLane Technology, AirPrint support
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 3
- 5 x 1000Base-T - RJ-45 , 1 x USB 3.0
- Vertical stand
- Power Device
- External power adapter
- Limited warranty - 2 years
