The NETGEAR EX6200 AC1200 Simultaneous Dual-Band Wireless-AC Range Extender boosts your existing network range and speed, delivering Wireless-AC dual-band WiFi up to 1200Mbps. The high-power design of this range extender provides ultimate range, while the dual core processor enables maximum WiFi performance. The NETGEAR EX6200 works with any standard WiFi router and is ideal for very large homes and frustration free HD video streaming and gaming.
Simultaneous Dual-Band Wireless-AC 802.11ac up to 1200Mbps
5 x Gigabit Ethernet Ports: Connect up to 5 wired devices
Amplified high-power design for ultimate wireless range/coverage
Dual core processor for max WiFi performance
Ideal for use with iPads, smartphones, laptops & more
Wirelessly share and access USB storage connected to the USB 3.0 port
Beamforming+: Focuses WiFi signals directly to wireless devices
Wireless Printing - Print documents & photos to any USB printer
FastLane Technology uses both WiFi bands for super high-speed connection
WiFi Analytics App
How strong is your WiFi signal? Use the NETGEAR WiFi Analytics app and get advanced analytics to optimise your existing or newly extended WiFi network. Check your network status, WiFi signal strength, identify crowded WiFi channels & much more!
Standard Warranty: 2-Years
Wi-Fi
Create faster dual band Wi-Fi access with 802.11ac technology up to 1200 Mbps. -
Ultimate range
700 mW high-power amplifiers and high-gain 5 dBi antennas for maximum Wi-Fi coverage. -
READYSHARE USB
Wirelessly share and access USB storage connected to the USB 3.0 port. -
Blazing fast CPU
Powerful dual core ARM A9 processor enables maximum Wi-Fi throughput at Gigabit speed. -
Beamforming+
Focuses Wi-Fi signals directly to wireless devices for more reliable connections. -
5 Gigabit Ethernet ports
Connect up to 5 wired devices like Blu-ray players, game consoles, smart TVs or streaming players to your Wi-Fi network. -
Wireless printing
Print documents and photos to any USB printer connected to the Wi-Fi range extender. -
FastLane technology
Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming and gaming.
- NETGEAR AC1200 WiFi Range Extender EX6200 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- ARM9
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Vertical stand
- 17.4 cm x 3.1 cm x 25.2 cm
- 302 g
- 2-year warranty
- 17.4 cm
- 3.1 cm
- 25.2 cm
- 302 g
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- ARM9
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Auto-sensing per device, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, on/off switches, FastLane Technology
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- 5 x 1000Base-T - RJ-45 , 1 x USB 3.0
- Vertical stand
- Power Device
- External power adapter
- Limited warranty - 2 years , Limited warranty - phone consulting - 90 days
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.03 |
