Say goodbye to Wi-Fi dead zones. Convenient, discreet and easy to install, extended Wi-Fi coverage is just an outlet away with this essentials edition extender. Boost your Wi-Fi for mobile devices and connect a wired device such as Smart TVs or game consoles.
Extend your range tour
Learn more about Wi-Fi Range Extenders and how you can boost your existing Wi-Fi network. -
Essentials edition
When all you need are the basics, Essentials Edition products are the perfect home network solution. -
Boost N300 Wi-Fi
Improve range and speed of your existing N300 Wi-Fi network. -
External antennas
For better Wi-Fi coverage and higher speed. -
Fast Ethernet port
Connect a wired device like a Blu-ray player, game console, TV or streaming player to your Wi-Fi network.
- NETGEAR EX2700 - Essentials Edition - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- 6.7 cm x 5.5 cm x 3.4 cm
- 98 g
- 2-year warranty
- 6.7 cm
- 5.5 cm
- 3.4 cm
- 98 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Firmware upgradable, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- Power Device
- Internal power supply
- Limited warranty - 2 years
