The NETGEAR AC1200 Wi-Fi High-Speed DSL modem router with dual band Gigabit is an incredibly fast modem router delivering AC1200 Wi-Fi and Gigabit Ethernet speeds. This DSL modem router provides a fast VDSL modem and it also works with ADSL connections. It offers extremely high performance in wireless coverage for large homes with 10 or more devices. With this AC1200 modem router you get 3x faster access than with similar 802.11n technology and more reliable streaming. It delivers the speed and reliability needed for applications such as smooth, lag-free, multiple HD video streaming, multi-player gaming, ultra-fast speed for a secure and reliable connection to the Internet.
Extreme speed
Speed makes HD video better. Speed makes online gaming awesome. Speed makes all your devices really go. And anyplace you need speed, with NETGEAR you got it. Extreme download speeds up to 300+900 Mbps. Next-generation 11ac Wi-Fi with dual band technology providing whole home coverage with Gigabit wired and wireless connection. Everything you need for a fast, fast, fast connected home. -
Wi-Fi range
Homes come in all shapes and sizes. The NETGEAR AC1200 Wi-Fi High-Speed DSL modem router with additional high-power amplifiers provides Wi-Fi connectivity throughout your home for all your Internet-enabled devices. -
Ultimate reliability
Stay connected - with your devices, your media, and your friends. Simultaneous Dual Band Wi-Fi provides two separate Wi-Fi networks - 2.4 GHz for legacy devices and 5 GHz which is less interference-prone for media streaming. The advanced QoS technology provides higher priority for media streaming application for smoother HD video streaming and low-latency online gaming. -
Easy sharing
Relive memories and share them with others. Find photos, videos and music stored on a shared USB hard drive and enjoy them on your DLNA TV right from your couch. If it's secure and shared storage access you want, NETGEAR has easy ways to do it. -
Secure experience
Keep your Internet browsing experience safe and secure with the free parental controls. It allows you to limit access to certain web sites at certain times. For example, no social networking or gaming site access after dinner time. Guest networks create a completely separate Wi-Fi network for your guests' devices, ensuring they do not have access to your home network or to the shared USB hard drive with all your personal data. Secure Wi-Fi connections offer high level WPA/WPA2 security.
- NETGEAR D6220 - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2+, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1200 Mbps
- Firewall protection, auto-sensing per device, NAT support, SPI, DoS attack prevention, IPv6 support, parental control, QoS, WPS, ReadySHARE, Push ‘N’ Connect button
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
- 24 cm x 18.2 cm x 4.1 cm
- 341 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
- Localisation
- United Kingdom
- Limited lifetime warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1200 Mbps
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK
- RAM
- 128 MB
- Flash Memory
- 128 MB
Communications
- DSL modem
- ADSL2+, VDSL2
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x VDSL / ADSL2+
Aerial
- Aerial
- External integrated
- Power Device
- External power adapter
- Included Accessories
- POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- Software Included
- NETGEAR Genie
- OS Required
- 24 cm
- 18.2 cm
- 4.1 cm
- 341 g
- Limited warranty - lifetime
