NetGear Aircard 790S 3G/4G Mobile Hotspot
Quicklinx: BYKVWS00 Mfr#: AC790-100EUS
Get a secure and incredibly fast 4G LTE Internet connection on the go. With amazingly long battery life and the ability to connect multiple Wi-Fi devices, you can access e-mail, news, and whatever matters most.
  • Effortless connectivity
    Experience seamless Internet access with the NETGEAR AirCard AC790's wireless connectivity technology. This mobile hotspot allows you to connect your devices to the Internet via 4G LTE networks, ensuring fast and reliable service wherever you go.
  • Advanced networking
    With compliance to IEEE 802.11ac and other standards, the NETGEAR AirCard AC790 offers robust wireless networking capabilities. It supports various data link protocols including IEEE 802.11ac, b, g, and n, making it versatile for different types of devices and usage scenarios.
  • Portable and powerful
    The NETGEAR AirCard AC790 is designed for mobility. Its internal antenna and compact form factor make it easy to carry, while the included lithium-ion battery ensures you stay connected even without a power outlet nearby.
  • User-friendly interface
    Equipped with a built-in display, the NETGEAR AirCard AC790 provides essential information at a glance. This feature enhances usability, allowing for easy management of your mobile hotspot settings and network status.
NETGEAR AirCard AC790 - mobile hotspot - 4G LTE
Mobile hotspot
External
Mobile Communication Protocol
HSPA, HSPA+, LTE
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Up to 11 hrs
Apple MacOS X 10.6.8 or later, Microsoft Windows XP Media Center Edition (32/64 bits), Windows RT, Microsoft Windows XP / Vista / 7 / 8 (32/64 bits)
11 cm x 15.44 cm x 6.8 cm
136 g
1.39 W/kg
Mobile hotspot
External
Built-in Devices
Display
Modem
Wireless
HSPA, HSPA+, LTE
Antenna
Internal
Antenna Qty
1
Wireless
1 x USB cable
1.39 W/kg
Lithium Ion
Up to 11 hrs
11 cm
15.44 cm
6.8 cm
136 g
