NETGEAR AC WiFi Business Access Point with Insight app for easy managment
Quicklinx: D577WS00 Mfr#: WAC505-10000S
  • IEEE 802.11n
The NETGEAR Insight Managed Wireless Access Point WAC505 delivers high performance WiFi and high client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC505 is managed by NETGEAR Insight app, for a more intuitive and innovative support, with no need for extra management hardware. The WAC505 features Multi-User MIMO (MU-MIMO) to achieve aggregate speeds up to 1.2 Gbps, option to configure as or Access Point modes, and comes with two Ethernet ports, a Power-over-Ethernet (PoE) 1Gb LAN port and a WAN port.
  • Enhanced connectivity
    With dual-band support, the NETGEAR WAC505 offers Wi-Fi 5 technology, ensuring robust connectivity across both 2.4 GHz and 5 GHz bands. This versatility enhances user experience by providing flexible network access tailored to a wide range of devices and applications.
  • Secure and reliable
    The device boasts advanced security features including Secure Shell (SSH), SSL, WPA, and WPA2 encryption algorithms. These protocols safeguard your network against unauthorized access and ensure a secure communication channel for all connected devices.
  • Efficient network management
    Equipped with features like 2T2R MIMO technology, VLAN support, and Multiple SSID support, the NETGEAR WAC505 facilitates efficient network management. It allows for enhanced signal quality, segmented network access, and the ability to manage multiple networks, ensuring optimal performance and ease of use.
  • Power over Ethernet (PoE) capability
    The device's PoE support simplifies deployment by eliminating the need for a separate power supply. This feature enables flexible installation options and reduces clutter, making it an ideal solution for various environments.
  • Comprehensive coverage
    With an aggregate throughput of 1.2 Gbps and support for Gigabit Ethernet, the NETGEAR WAC505 delivers high-speed Internet access. It's designed to meet the demands of high-bandwidth applications, ensuring smooth streaming, gaming, and downloading experiences across all connected devices.
NETGEAR WAC505 - radio access point - Wi-Fi 5
Radio access point
External
Worldwide (excluding United States and Canada)
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
17.5 cm x 16.5 cm x 3.5 cm
256 g
5-year warranty
Radio access point
17.5 cm
16.5 cm
3.5 cm
256 g
External
Wired
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, SNMP 2c, SSH
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, WLAN, LAN, link/activity
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, manageable, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, Management Information Base (MIB), 802.1x authentication, Transmit Power Control (TPC), MAC address authentication
Encryption Algorithm
SSL, WPA, WPA2
Authentication Method
Secure Shell (SSH)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45 (WAN)
PoE
8.9 watt
Limited warranty - 5 years
