NETGEAR 4Pt Orbi Pro Satellite
Quicklinx: D9RGWS00 Mfr#: SRS60-100UKS
  • IEEE 802.11n
NETGEAR Orbi Pro SRS60 Wi-Fi range extender Dual Band DC power.
  • Enhanced connectivity
    With six internal antennas and tri-band technology, the NETGEAR Orbi Pro SRS60 ensures comprehensive coverage and superior wireless performance. Its ability to support simultaneous connections across 2.4 GHz and 5 GHz bands with Wi-Fi 5 technology makes it ideal for a wide range of devices.
  • High-speed data transfer
    Experience seamless Internet with a data transfer rate of up to 3000 Mbps. The NETGEAR Orbi Pro SRS60 is equipped with MU-MIMO and beamforming technology, optimizing the data path to your devices and ensuring efficient, high-speed Internet access for multiple users simultaneously.
  • Secure networking
    Keep your network safe with WPA and WPA2-PSK encryption algorithms. The NETGEAR Orbi Pro SRS60 provides a secure connection, protecting sensitive data from unauthorized access and ensuring a safe Internet environment for all users.
NETGEAR Orbi Pro SRS60 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wall mounting kit, ceiling mounting kit
DC 12 V
17.4 cm x 8.5 cm x 24.7 cm
930 g
Technical support
17.4 cm
8.5 cm
24.7 cm
930 g
United Kingdom
External
Wireless
Data Transfer Rate
3000 Mbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC3000
MU-MIMO technology, beamforming technology
Encryption Algorithm
WPA, WPA2-PSK
Aerial
Antenna
Internal
Antenna Qty
6
4 x 1000Base-T - RJ-45
External power adapter
DC 12 V
Technical support - 90 days
