The NETGEAR R6100 Wi-Fi Router with AC1200 dual band is an incredibly fast router delivering AC1200 Wi-Fi speeds. This router offers improved performance and wireless coverage for your home. The R6100 gets 3x faster access than similar 802.11n technology and delivers the speed and reliability needed for applications such as multiple HD streaming, online gaming and a secure and reliable connection to the Internet. The R6100 also includes NETGEAR genie home network manager for easy installation and home network management.
Compatible with next generation Wi-Fi devices and backward compatible with 802.11 a/b/g/n devices, it enables HD streaming throughout your home. With up to 300+867 Mbps speed and simultaneous dual band Wi-Fi technology, the R6100 avoids wireless interference, ensuring top Wi-Fi speeds and reliable connections.
Enhanced security
With support for WPA-PSK and WPA2-PSK encryption algorithms, the NETGEAR R6100 ensures your network remains secure against unauthorized access, providing peace of mind for sensitive data transmission. -
Versatile connectivity
Featuring both wired and wireless connectivity options, including Ethernet 10Base-T/100Base-TX and 802.11a/b/g/n/ac wireless protocols, this router offers flexible connection solutions for a variety of devices and setups. -
Comprehensive control
Circle Smart Parental Controls and Quality of Service (QoS) features allow for easy management of Internet access and bandwidth prioritization, ensuring a smooth online experience for all users. -
Dual-band advantage
With the capability to operate on both 2.4 GHz and 5 GHz Wi-Fi bands, the R6100 router provides a more reliable signal and flexible network optimization, catering to all your connectivity needs. -
Easy sharing and storage
The inclusion of a USB 2.0 port with ReadySHARE allows for easy sharing of storage devices over the network, making it simple to access and share files, music, and videos across multiple devices.
- NETGEAR R6100 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1200 Mbps
- NAT support, Stateful Packet Inspection (SPI), IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, reset button, Denial of Service (DoS), Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
- 18 cm x 17 cm x 6 cm
- 322 g
- Microsoft Certification
- Compatible with Windows 7
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1200 Mbps
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- RAM
- 128 MB
- Flash Memory
- 128 MB
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- 18 cm
- 17 cm
- 6 cm
- 322 g
