The NETGEAR AC WiFi Business Access Point WAC510 delivers high performance with high client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC510 features Multi-User MIMO (MU-MIMO) to achieve aggregate speeds up to 1.2 Gbps and option to configure as Router or Access Point modes.
- NETGEAR Insight Managed Smart Cloud (WAC510) - wireless router - 802.11a/b/g/n/ac Wave 2 - desktop, wall-mountable, ceiling-mountable
- Wireless router
- Packaged Quantity
- 3 (specifications are for single item)
- Enclosure Type
- Desktop, wall-mountable, ceiling-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Maximum number of clients: 200
- Bonjour
- Remote Management Protocol
- SNMP 1, SNMP 2c, SSH
- VLAN support, auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, rogue access point detection, Transmit Power Control (TPC), band steering, guest access, 2x2:2 MU-MIMO technology, WDS bridge PtP mode, WDS bridge PtMP mode
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
- 19.732 cm x 19.732 cm x 3.7 cm
- 555.5 g
- Localisation
- Worldwide (excluding United States and Canada)
- Packaged Quantity
- Wireless router
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Bonjour
- Encryption Algorithm
- SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Secure Shell (SSH), RADIUS, Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
- Wi-Fi Rating
- AC1300
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2, EN 60950
- Status Indicators
- Power, LAN, link/activity, 2.4/5 GHz
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- 9.3 Watt
- Included Accessories
- Wall mounting kit, ceiling mounting kit
- Mounting Kit
- Included
- MTBF
- 978,210 hours
- Localisation
- 19.732 cm
- 19.732 cm
- 3.7 cm
- 555.5 g
- 0 °C
- 40 °C
- 10 - 90%
