NetGear 16-Port Gigabit Ethernet Unmanaged Desktop Switch
Quicklinx: BW21WS00 Mfr#: GS316-100UKS
The NETGEAR 16-Port Gigabit Ethernet Switch with simple plug-and-play, compact desktop design, and auto-sensing ports provides easy, reliable, and affordable connectivity for your home or small office network. A rugged metal enclosure, silent, fanless design, and wall mount kit allow for convenient deployment to build out your SOHO network. Auto-MDI/MDIX (eliminating the need for crossover cables), jumbo packet support, auto-negotiation for automatic connection at highest speeds, non-blocking switching architecture for maximum throughput, and energy-efficient technology for power savings (IEEE 802.3az and short cable power reduction) make the GS316 the perfect switch for the SOHO environment.
NETGEAR SOHO GS316 - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Bandwidth: 32 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 3.9 µs
MAC Address Table Size
2K entries
Jumbo Frame Support
9270 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), fanless, 768KB packet buffer, Energy-Efficient Ethernet (EEE)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
28.6 cm x 10.1 cm x 2.6 cm
840 g
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
2K entries
Jumbo Frame Support
9270 bytes
Status Indicators
Power, link/activity
16 x 1000Base-T RJ-45
External power adapter
8.4 Watt
Power Consumption Stand by
1.83 Watt
Plug and Play
28.6 cm
10.1 cm
2.6 cm
840 g
Limited warranty - 3 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
