M5300 series provides largest 10 Gigabit choice for uplinks with SFP+ ports for fiber optic or short, low-latency copper DAC cables; 10GBase-T ports for legacy Cat6 RJ45 short connections (up to 50m) and Cat6A connections up to 100m; CX4 for legacy 802.3ak infiniband wiring.
High-speed connectivity
Experience fast data transfer rates of up to 10 Gbps with the NETGEAR expansion module. Designed for efficiency and speed, this module ensures that your PC stays ahead in the digital world. -
Seamless integration
With its Plug-and-Play module form factor, this NETGEAR product offers an easy upgrade to 10Gb Ethernet, ensuring a smooth and straightforward integration into your existing setup. -
Robust compatibility
The module's compatibility with Ethernet 10GBase-T and compliance with IEEE 802.3an standards means it can easily fit into a wide range of networking environments, making it a versatile choice for any PC.
- NETGEAR - expansion module - 10Gb Ethernet
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 10Gb Ethernet
- Cabling Type
- Ethernet 10GBase-T
- Data Link Protocol
- 10GbE
- Data Transfer Rate
- 10 Gbps
- IEEE 802.3an
- 5-year warranty
- Designed For
- NETGEAR GSM7228PS, GSM7252PS, GSM7328S, GSM7328Sv2, GSM7352S, GSM7352Sv2; Next-Gen Edge Managed Switch M5300-28G, M5300-28GF3, M5300-52G
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 10Gb Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- IEEE 802.3an
- 1 x 10GBase-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- Limited warranty - 5 years
- Designed For
- NETGEAR GSM7228PS, GSM7252PS, GSM7328S, GSM7328Sv2, GSM7352S, GSM7352Sv2 , NETGEAR Next-Gen Edge Managed Switch M5300-28G, M5300-28GF3, M5300-52G
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
