NEC MultiSync PA242W 24" 1920x1200 DVI HDMI DisplayPort LED Monitor Black
Quicklinx: 993KWS00 Mfr#: 60003490
Featuring a cutting edge GB-R LED-backlight, the PA242W, a 24" AH-IPS LCD monitor, is the another standard for color accurate applications including photography and video editing. Offering an accurate 100% coverage of sRGB color gamut and 99.3% of Adobe RGB, the PA242W includes internal 14-bit 3D programmable lookup tables (LUTs) for accurate color rendition, 10-bit DisplayPort and HDMI connectivity for the highest color fidelity and built-in USB hub with DisplaySync Pro.
NEC MultiSync PA242W - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class C
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey), 16 ms (On/Off)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
55.68 cm x 22.76 cm x 37.8 cm
10.6 kg
Microsoft Certification
Compatible with Windows 7
FCC Class B certified, MPR II, CSA, UL, TUV GS, C-Tick, GOST, cUL, DDC-2B, MPR III, PCBC, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP
3-year warranty
Display Type
Energy Class
Class C
54 kWh
Diagonal Size
24.1"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 85 Hz
Horizontal Refresh Rate
31.5 - 118.4 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
GB-r LED backlight
Picture in picture, OmniColor, CableComp, Rapid Response, Advanced No Touch Auto Adjust, sRGB colour management, TileMatrix, NaViSet, ColorComp, Eco-Mode, Overdrive technology, TileComp, RapidMotion, OSD lock, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
55.68 cm x 22.76 cm x 37.8 cm - with stand
10.6 kg
DVI-D , HDMI , DisplayPort , VGA , 2 x USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, 200 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x Mini DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
Input Voltage
AC 120/230 V
37 W
Power Consumption (Typical)
56 Watt
Power Consumption Stand by
2 Watt
Dimensions & Weight Details
Without stand - width: 55.68 cm - depth: 8.5 cm - height: 36.24 cm - weight: 7.4 kg , With stand - width: 55.68 cm - depth: 22.76 cm - height: 37.8 cm - weight: 10.6 kg
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
