NEC EA241WM 24"White DVI 1920x1200
Quicklinx: 5FGQWS00 Mfr#: 60002511
The ECO mode reduces power consumption, and the carbon meter indicates the accumulated amount of reduced carbon dioxide. The energy-saving 24-inch wide models LCD monitors are optimum solutions for enterprises introducing multiple monitors.
  • ECO mode saves power consumption
    Lower power consumption by reducing the brightness to the lowest level that can be used for normal operation.
  • Carbon meter (the function indicating the accumulated amount of the reduced carbon dioxide)
    The accumulated amount of reduced CO2 emissions (kg) as a result of saving on power consumption with the ECO mode.
  • The stand height adjustment function is capable of adjusting the height within the range of 110 mm
    With the stand height adjustment function raising/lowering the height of the monitor up to 110 mm, the monitor can be set at a visible position for the user or as necessary for the use environments. The angle of the monitor can also be adjusted vertically and horizontally.
  • LED brightness adjustment function
    The brightness of the power supply lamp is adjustable, so that it will not interfere with displayed images when viewing dark scenes or in a multi-display environment.
  • The 2-system input is available in standard configuration
    With the 2-system Input, it is possible to connect two PCs to the monitor at the same time and control them independently. The DVI-D connector for digital signals and the Mini-S-SUB15 pin for analog signals are used. The button on the front panel switches the input signals. For digital input, initial settings for the screen are not required. It is possible to reproduce real images with significantly less signal deterioration.
  • The monitor has built-in stereo speakers
    The main unit of the monitor has stereo speakers. Contents having various kinds of digital sounds can reproduce.
  • Excellent picture quality with PVA TFT
    Stable and excellent picture quality with NTAA (Non-Touch-Auto-Adjustment) and PVA TFT display.
NEC MultiSync EA241WM - LCD monitor - 24"
LCD monitor - 24"
Stereo speakers, USB 2.0 hub
Panel Type
TN
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
White, silver
55.9 cm x 27.2 cm x 54.7 cm
10.5 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, ISO 13406-2, MPR III, VESA EDID, CCC, TUV Ergo, DDC/CI, GEEA
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Built-in Devices
Panel Type
TN
Native Resolution
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
81.1 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Controls & Adjustments
Brightness, contrast, colour temperature
No Touch Auto Adjust, sRGB colour management, HDCP, NaViSet, Eco-Mode
White, silver
10.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI-D , 4 x USB 2.0 downstream , USB 2.0 upstream , VGA
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
52 Watt
Power Consumption Stand by / Sleep
2 Watt
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
