Certified by TÜV for 4-star eye comfort, this 16:10 monitor provides enhanced visual comfort, seamless connectivity, and a productivity boost.
Improved ComfortView Plus
Reduces harmful blue light emissions to =35%, for all-day comfort without sacrificing color. -
Refresh rate
100 Hz refresh rate delivers less flicker, more seamless scrolling and smoother motion. -
Vivid colors
Wide color coverage with up to 16.7 m displayable colors of 99% sRGB. -
Color consistency
Vibrant colors across wide viewing angles enabled by In-Plane Switching (IPS) technology. -
1500:1 contrast ratio
For deeper blacks and brighter whites. -
Extensive connectivity
Wide variety of ports for all your accessories. -
Quick access USB ports
Including a USB-C downstream that delivers up to 15W of power. -
Improved multitasking
Organize your screen with Easy Arrange and save profiles with Easy Arrange Memory. -
Smooth deployment
Manage your fleet of monitors with features that are automatic, comprehensive and compatible with several tools. -
Convenient customization
Quickly access your favorite features and functions with the menu launcher and hot keys. -
Design innovation
This monitor has been thoughtfully crafted with sustainable materials including 85% recycled plastics with post-consumer recycled plastic and closed-loop ITE-derived plastic, 50% recycled steel, 100% recycled aluminum and at least 20% recycled glass. -
Energy conservation
Using PowerNap mode in Dell Display Manager lowers energy use by up to 14.8%. -
Excellence in environmental standards
This monitor is certified ENERGY STAR 8.0, carries the TCO Certified Edge designation, and is registered EPEAT Gold with Climate+. With Climate+, this monitor has met industry best practices around decarbonization.
- Dell P2425 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1870858
- Energy Class
- Class D
- Power Consumption (On mode)
- 13.6 W
- USB 3.2 Gen 1 hub, USB PD 15 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 53.18 cm x 18.175 cm x 36.4 cm
- 4.66 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- Carbon Footprint
- 162 kg carbon emissions
- Plug and Play, RoHS, BFR-free, PVC-free
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.2 Gen 1 hub
- USB Power Delivery
- 15 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94.07
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 122 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
- 53.18 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
- 4.66 kg
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
- 1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.6 W
- Power Consumption SDR (On mode)
- 13.6 kWh/1000h
- Power Consumption (Typical)
- 12.2 watt
- Power Consumption (Max)
- 74 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.18 cm - depth: 18.175 cm - height: 36.4 cm - weight: 4.66 kg , With stand (highest position) - width: 53.18 cm - depth: 18.175 cm - height: 51.12 cm - weight: 4.66 kg , Without stand - width: 53.18 cm - depth: 5.003 cm - height: 34.37 cm - weight: 3.15 kg
- Shipping Weight
- 6.75 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 78.57
- Logistics (kg CO2e)
- 12.64
- Use (kg CO2e)
- 66.74
- EOL (kg CO2e)
- 3.89
- Total Carbon w/o Use Phase (kg CO2e)
- 95.26
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £110.82 |
Other bundles (1)
Dell SB521A Magnetic Sound bar | In Stock | £36.88 |
